Cylinder head interchangability
Old Nov 12, 2009 | 11:27 PM
tanda10506's Avatar
Will heads off of older small block chevy's bolt on to an 87 and up block. I want to use the standard small block chevy carbureted intake with an adapter plate for the throttle body so don't worry about intake problems, I'm just talking about the block. Thanks.
Old Nov 13, 2009 | 12:05 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: Cylinder head interchangability
Yes, use a new bolt set for early heads & double check pushrod lengths.
Old Nov 14, 2009 | 02:22 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
You can use the older heads but you have to use the 86' and earlier intake as well. Pushrod length should be okay as I think it travels the same length with the only difference between the two pushrods being that roller cams use shorter(I think?) lengths. New head bolts are pretty cheap and provide some peace of mind ,plus the old ones will probably look pretty nasty!
Cornholio7979
Sep 20, 2018 02:31 AM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
