Fuel pressure issue?
I have a 92 305 camaro with the tbi fuel system and the car will start up great but then lops and will die. I can hear the fuel pump but I hooked up a pressure gauge up to it and it was really low below 15 psi. I have replaced the fuel filter. Aside from replacing the fuel pump is there anything else I should try?
Any help is much appreciated.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fuel pressure issue?
TBI system is supposed to be only about 12psi. Check for vacuum leaks, make sure plug wires are good (check continuity on each).
Maybe this post is older but here is a thought. If your fuel pressure is far below 12psi and you can hear your fuel pump this seems self explanatory.
Its most likely not a vac. leak. and has nothing to do with your plugs. its your fuel system. so start with the pump sense you can hear it and you shouldn't be hearing it, or you can do a regulator diaphragm rebuild kit. 50-100 bucks from checker.
mdtoren
Aug 16, 2015 05:45 PM
