TBI sputtering. help!!
Old Nov 23, 2009 | 02:20 PM
bschafert's Avatar
Car: 91 RS
Transmission: Soon to be T56
Axle/Gears: 3:23
i swapped my motor over to a 350 from 305 with the same tbi and aftermarket intake cam etc basically its a mild build. i took it to the track and was running 13.50's it was running good and reliably for the longest time. i put new injectors on it and it slowly aquired a sputtering problem. i thought it was the injectors so i swapped the stock ones back in. that didnt fix it. if i let it idle it will run for about five minutes then stall. at one point it would backfire through the exhaust now it seems to be through the intake. i changed out the fuel filter thinking it could have been dirty fuel and disconnected the battery now when i take my key out the fan continues running and it still sputters. any help will be appreciated.
Old Nov 24, 2009 | 12:11 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: TBI sputtering. help!!
is the SES light on? whats your fuel pressure at?
Old Nov 30, 2009 | 04:01 PM
bschafert's Avatar
Car: 91 RS
Axle/Gears: 3:23
no lights are on. idk what fuel pressure is. i havent checked it. im about to just give up and swap to carb and just eliminate the comp. all together
Old Nov 30, 2009 | 04:42 PM
Ronny's Avatar
check fuel pressure at idle and then rev it and check again. How old is FP?
Old Dec 2, 2009 | 03:47 PM
bschafert's Avatar
Car: 91 RS
Axle/Gears: 3:23
i believe it is the stock fuel pump. the car has 78000 miles.
Old Dec 3, 2009 | 10:42 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
When you say it's 'sputtering', do you mean it seems to be getting too much fuel or too little? If it's too much, check the CTS - they can go bad w/ age. When mine went bad simply disconnecting it made the engine immediately start idling better and the injectors running like they should. If it's bad, it's less than $20 to replace.
If it's too little, check the fuel pressure as others have already suggested. It could be the fuel pump or the fuel pressure regulator diaphram. The regulator can be repaired w/o removing the throttle body.
You also mentioned the fan is running and I assume the engine hasn't run long enough for them to be on yet. The ecm might be getting a signal that the engine is hot, leaning the mixture out, and turning the fan on. Again, a bad CTS may be the culprit.
Finally, you can find out a lot by connecting a laptop up to the ALDL port and running WinALDL or TunerPro to monitor sensor signals to the ECM. You can buy a cable for a serial or usb port. A serial port cable can be built fairly easily. The software is available for free.
I'd definitely check some things out before tossing the TBI for a carb. But, that's just my opinion.
Hope this helps.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
