thoughts on engine recipe
Old Nov 30, 2009 | 09:20 PM
gravedigger472's Avatar
im rebuilding my the engine in my 1989 K2500. its a 350TBI and i have a few questions about what parts to use. im going to use the stock bottom end and freshen up as necessary. the build is going to be mild and on a budget of approx $1500. im not expecting 300HP but close would be nice. i want the power low down, and a fat TQ curve is nice.
heads: ported 193 TBI truck heads
cam: 212 to 218°@.050 and about .460 lift hyd flat tappet
intake: Weiand Team-G, (already have it) and will build a heated TBI to 4BBL adapter.
throttle body will get ultimate mods, stock injectors, walboro 190LPH, 18psi regulator, possibly 50mm bored
RBob's EBL
also is getting headers, Y-pipe, cat back, CAI, cat delete. i recently tuned it up with new O2, AC-Delco plugs, MAP, and all that jazz.
what do you think of the cam? remember im on a tight budget. i can perform anything myself, just not a surplus of $$$ at this time. im not expecting a ton of power, just more than stock.
Old Nov 30, 2009 | 10:12 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: thoughts on engine recipe
some of the earlier TBI trucks got a Hyd roller IIRC, if yours is I would go roller. also, I would sell the Team G and get a dual plane if you want low end torque.
Old Nov 30, 2009 | 10:55 PM
yes i believe the block is drilled for a roller cam but does not have one installed.
Old Nov 30, 2009 | 11:28 PM
ericjon262's Avatar
just a thought, I got lifters spider camplate and dogbornes for $25 at a local U pull it yard,
Old Mar 9, 2021 | 07:22 PM
Clayton!'s Avatar
Car: O3 Chevy g20
Transmission: 4l60e
Wrong post, Sorry..
Old Mar 9, 2021 | 07:23 PM
Clayton!'s Avatar
Car: O3 Chevy g20
Transmission: 4l60e
My 93 is not drilled for a roller cam, Some were though.
Kyler_89RS
Sep 9, 2017 08:24 AM
rnx
Jul 28, 2013 05:34 AM
Gordiggz
Oct 23, 2008 05:46 PM
davep_96
Mar 24, 2008 05:49 PM
Darkshot
Jul 17, 2007 01:24 AM
