for the love of..........nvm. need a couple pointers
Old Dec 1, 2009 | 12:16 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
finally killed my 305, sitting at a red light.....go figure. lives through a 4 gear burn out to come apart at a red light. towing it into work tomo to pull the motor out and re build it most likely. if it's saveable. goin on friday to pick up the lt1 cam, 1.6 rockers. heavier flexplate, 350 injectors, and any upgrades I come accross at the junk yard.
but the main pointer I need is where do or should I go for a chip....i see alot dont like tbichips.com and pcmforless wont touch me. already running lean and iffy at idle with holley intake, fullignition minus box, tbi mods, headers with dual side pipes, a/c and smog delete, open k/n element, 2.4k stall full stage 3 manual shift kit, tpi fuel pump, true double roller timing chain, hi vol oil pump.....
oh and getting the heads ported and poilished while they're out
Old Dec 1, 2009 | 12:59 AM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
Re: for the love of..........nvm. need a couple pointers
Sooo what exactly "came apart"????
Sounds like a good time to upgrade to a new block...
Old Dec 2, 2009 | 11:59 PM
Car: 91 RS
Engine: 5.0 tbi
not sure only way I can go to a new block block right now is if mine is shreaded when I take it apart. if not taxes are gonna alot me a full new suspension includein rear so I'll roll the 305 another year or 2
tow truck cant get me there till this week end. worst part about callin in favors.
Old Dec 3, 2009 | 01:08 AM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
might as well spend another 300 bucks on a good 350 block. 45 more displacement that youll def notice. hell i got 3 good blocks laying around that im selling 100 bucks a piece
Old Dec 3, 2009 | 08:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If those are the LO3 heads, you're wasting your time - porting/polishing it easier to run the chain through those boat anchors.
Maybe look into the Dynamic EFI stuff - supposed to be a newer easier way to do your own chip programming with flash proms and laptop programming on the fly while you drive. But If I had any programming know-how, maybe I wouldn't have gone carbed.
Nah - take that back, I'd still be carb - I like turning wrenches way better than screwing with programming!
LittleFranks
Oct 7, 2015 11:26 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
Magman
Sep 13, 2015 12:14 AM
Randomtask2
Sep 10, 2015 08:37 AM
rudolphschenker
Sep 4, 2015 02:41 AM
