lets see some customized throttle bodies
Old Nov 18, 2009 | 10:37 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
post some pics of your modified TBI stuff, I'll go first.
I'm not finished yet, but getting there!
Old Nov 19, 2009 | 10:28 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Re: lets see some customized throttle bodies
Very nice, I need to do this myself. How did you go about smoothing the lips around the throttle bores?
Old Nov 19, 2009 | 10:39 AM
ericjon262's Avatar
I did all of it with a dremel tool and several different cutters, and a abrasive polishing wheel. that throttle body probably has 6-8 hours worth of grinding and polishing in it. dont use grinding stones the clog up very quick, use carbide burrs, they don't clog unless you spin them too fast.
I'm not done with it yet, but I'm getting pretty close.
Old Nov 19, 2009 | 03:55 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
TB can also be sent to turbocity to be bored, thin trottle shafts installed, rebushing, ...
http://www.chevyhiperformance.com/te.../photo_05.html
I will take a pic of mine and post it these next days.
Old Nov 21, 2009 | 08:52 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
https://www.thirdgen.org/forums/tbi/...?highlight=UFO
Old Nov 21, 2009 | 07:26 PM
ericjon262's Avatar
Thats awesome, I've never seen anything like that!
Old Nov 28, 2009 | 10:50 AM
ericjon262's Avatar
there's got to be more than just these 2(3 if you include the mag)! anyone running a 4bbl? CFI? lets see it
Old Dec 3, 2009 | 09:56 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Since taking these pics I've modified the regulator to be adjustable. A sockethead screw (not shown) between the two fuel fittings allows for adjustment. If you look closely, you'll also see the shaved throttle shafts in the pic of the fuel fitting reliefs.
Attached Thumbnails lets see some customized throttle bodies-mod2front01.jpg   lets see some customized throttle bodies-mod2fuellinerelief01.jpg
Street Lethal
Apr 30, 2019 12:14 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
hayesaw0210
Aug 23, 2015 11:15 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
