No voltage
Old Dec 5, 2009 | 01:45 PM
madaustinite's Avatar
No voltage
I have a 91 RS camaro with the 305 TBI. Im getting voltage at the injector fuses but i cant get voltage to the injectors. The fuses are good. What comes after the fuses and can someone give me a picture and schematics that actually are good. This hanes manual blows when it comes to telling me where things are. Thanks!
Old Dec 5, 2009 | 02:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: No voltage
The ignition switch feeds the fuses (INJ1 and INJ2). Each fuse then goes on to the engine harness to the injectors. These are the red & white wires at the injectors.
The diagram shows a feed through at the "engine to I/P connector". Pins B & G. Looking at what other ECM wires go to this I/P connector, it is likely located under the dash. I/P usually stands for instrument panel, but it can't be going to the cluster.
Ah, found it, connector C207. Located behind right hand side of instrument panel. Looks to be a two row connector. From there it goes on to where the ECM is and continues on to the injectors via the ECM harness.
RBob.
Old Dec 5, 2009 | 03:23 PM
Re: No voltage
so it just goes into the ecm after the fuses then to the injectors?
Old Dec 5, 2009 | 04:27 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: No voltage
No, the injector +12 V goes to the ECM harness and on to the injectors. Note that the ECM harness passes through near the passenger door into the engine compartment.
The only connection from the injectors to the ECM are on the low side. That is the ECM grounds the injectors to turn them on (pulse them).
RBob.
Elephantismo
Feb 13, 2019 12:51 AM
327IROC85
Sep 23, 2015 12:11 AM
eustodp
Sep 20, 2015 05:09 PM
ULTM8Z
Sep 16, 2015 09:15 AM
RyanJB
Sep 2, 2015 01:27 PM
