TPI fuel pump in TBI?
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
I think this is possible based on a couple threads that i saw when searching but just want to be sure. Can you use the TPI fuel pump with the TBI motor? Sometime down the road I'd like to change the car over to a TPI setup, I'm going to change the tank this winter and if it'll work I'd rather put a new fuel pump in right away instead of doing it again in a year or two.
Car: check
Engine: check
Transmission: check
Re: TPI fuel pump in TBI?
RBob.
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
the tbi and tpi all use the same pump nothing is different even the 5.7 tbi trucks use the same pump as a 5.0 or 5.7 tpi/tbi
Car: check
Engine: check
Transmission: check
The stock TBI pump is a turbine pump. And can barely produce 20 psi when dead headed.
RBob.
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
right on, they are pretty different. i haven't measured my fuel pressure but i'm using a TPI pump (i think it was AC Delco EP #241) in my TBI and it's working fine and gives you room for some future mods.
Rbob, care to explain the meaning of "gets the turtle" and "deadhead"?
thx
thx Joined: Sep 2005
Car: 92 camaro RS
Engine: LSA
thats why i checked them at my dads napa auto parts store and they all use the same part numbers? get on napa's online site they dont even list a difference between the tbi-tpi fuel pumps! why cause there is none.
Car: check
Engine: check
Transmission: check
thx
thxDead head is when there is no fuel flow. The fuel pump is providing as much pressure as it can.
RBob.
Car: check
Engine: check
Transmission: check
Being that the replacement pump for a TBI is the same as the TPI pump also confirms what I said about being able to use the TPI pump.
RBob.
Engine: LS1 / L03
Nope, it should regulate the pressure down just fine as long as your return line to the tank is all good.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Ugh I thought I was sending a pm. Too much window juggling, I didnt mean to resurrect a 5 year old thread. Since the post is here and I cant do anything about it I guess I will put the question back in...
Does the TBI pump not use the SAE J30R10 fuel line that the TPI pump has?
Engine: LS1 / L03
NP, dont worry.. imho Bob recommended this hose because of its material properties according to that SAE standard, because some just use random hoses only to drop the tank again after it splits or similar. Thinking it should be the same for TBI, TPI, etc.
But while you're in there replacing the pump, also put in some new proper hose
Think that was the point.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
