lo5 can it make good power?
Old Dec 29, 2009 | 05:26 PM
effinbird's Avatar
i just recieved an lo5 out of a suburban for a real good deal that im looking to put into my 89 firebird. Before i do i plan on rebuilding the motor and i was wonder if its possible to get 350 fwhp out of an lo5. i know the heads are trash so im scrapping those and the cam of course, but will the tbi setup be able to hack it?
Old Dec 29, 2009 | 08:04 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Re: lo5 can it make good power?
Well the heads and cam are kinda what makes it a LO5. Throw those out and it's just small block short block. Will the stock LO5 TBI get you to 350 BHP...no, not enough fuel and barely enough airflow.
Old Dec 29, 2009 | 08:37 PM
effinbird's Avatar
will a modified tbi system be able to? say zz4 intake with a holly tbi?
Old Dec 30, 2009 | 11:26 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
With some really good heads and a nice cam it should be easy.
The 46mm (590cfm) TB should be ok for 350fwhp, otherwise you can always use the 50mm one or some aftermarket TB.
For fueling a walbro 190 +, some 68#/hr injectors, 24psi VAFPR will take care of it with some reserve just for the case.
To tune it and run it the best and simplest would be EBL flash.
Read all the sticky treads on top of the board, will give you a good idea of what TBI is capable of.
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Brcharrelson
Aug 26, 2015 07:47 PM
InfinityShade
Aug 22, 2015 08:00 PM
