MSD coil issues.
Old Jan 2, 2010 | 01:24 AM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
MSD coil issues.
anybody here using the msd streetblaster coil , im having clearance issues . it wont clear the intake manifold runner " #7 " so i can only bolt one side down . and if i bolt it on the opposite side of the coil it hits the dizzy cap . btw this is with the installation kit it came with . what did you do to fix this ?
Old Jan 8, 2010 | 08:01 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: MSD coil issues.
I had issues when installing aftermarket coils before on my tbi setup. I ended up elongating the mounting bracket bolt holes to allow a little more flexibility in position. Maybe try some longer mounting bolts and some spacers underneath to raise it up a bit? Any pictures of the problem? May help with fixing the issue for you
Old Jan 13, 2010 | 02:43 PM
sinkorskin's Avatar
I bought an MSD blasterfor my 91 rs and id have clearance issues. Especially with the KN 3x14 Open element. My solution (temporary) was to only affix one bolt and bend the holder a bit. It fits and i noticed a slight increase in response. Btw I didnt go with th street fire it is an all red case even around te bolt holes.
Old Jan 18, 2010 | 09:46 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
I mounted mine to the firewall next to the windshield washer motor
Old Jan 19, 2010 | 05:44 PM
problem solved , thanks for the help
Fanatic1074
Oct 3, 2022 05:57 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
meeklay812
Oct 1, 2015 03:46 PM
