ONLY 10.5 PSI OF FUEL PRESSURE. NEED HELP
Old Jan 27, 2010 | 03:30 PM
anthonyrs's Avatar
Car: 1991 CAMARO RS,1997 FORD EXPLORER
Engine: NO MORE 305. 350 NOW
Axle/Gears: 273 NEED NEW ONES
I HAVE A 1991 CAMARO 305 TBI. I PUT A NEW EDELBROCK CAM N LIFTERS TIMMING CHAIN. HEADERS WITH Y-PIPE AND NO CAT. OPEN AIR ELEMENT. THE CAR RAN AWESOME AND THEN IT STARTED TO RUN LIKE IT WAS MISSING THE ONLY WAY TO KEEP IT FROM STALLING IS TO HOLD THE GAS PEDEL DOWN. SINCE THAT I PUT A BRAND NEW DISTRUBITER AND CAP N COIL N PLUGS N WIRES N NEW O2 SENSOR N MAP SENSOR. AND A NEW FUEL FILTER AND CHANGED THE GAS CAR STILL RUNS LIKE CRAP. I CHECK THE FUEL PRESSURE TODAY AND IT WAS ONLY AT 10.5 PSI AND I WAS WONDERING IS THE THE PROBLEM? THANKS ALOT FOR ANY INPUT.
Old Jan 27, 2010 | 04:38 PM
anthonyrs's Avatar
Re: ONLY 10.5 PSI OF FUEL PRESSURE. NEED HELP
I JUST CHECKED THE FUEL PRESSURE AGAIN BUT THIS TIME I HAD THE KEY FORWARD BUT NOT RUNNING AND THE FUEL PRESSURE WENT TO 10.5 TO TO 0. I AM SURE NOW ITS THE FUEL PUMP.
Old Jan 27, 2010 | 04:42 PM
Twin_Turbo's Avatar
10.5 is fine and with the ign. in the on position the pump will only run for a couple of secs and then turn off. It will only start running again when cranking or when you turn the ign off, wait for about 30 secs and turn it on again. Then it'll run for another couple of secs.
Old Jan 28, 2010 | 12:25 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Transmission: 700r4 stock
how do you check the fuel pressure and how much pressure is it supposed to have.
Old Jan 28, 2010 | 07:32 PM
anthonyrs's Avatar
you need to buy an adapter thats made for the tbi engines and a fuel pressure gauge. do a google search. i will post a pic of it soon.
Old Jan 28, 2010 | 07:35 PM
anthonyrs's Avatar
thanks alot for the info. do you have any other ideas? i have a new but used computer and modular comming from ebay. $25. tomorrow i am going to take the valve covers off and see if the rockers arms are moving.
9192camaro
16
Feb 3, 2019 12:21 AM
fasteddi
Sep 2, 2015 10:29 AM
CORV3TT3
Aug 23, 2015 11:26 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
Kaweh
Aug 9, 2015 02:54 PM
