454 to 350 TPS/IAC matched wires by color(?)
Old Feb 3, 2010 | 11:47 AM
gravedigger472's Avatar
I just completed my 454 swap into my 1989 K2500 and am having some issues im trying to rule out.
When wiring the TPS and IAC i just matched the colors of the wires up, but A,B, and C did not correspond between the 2 harnesses. Did i connect any of the wrong? What wires (ABC) should do what?
BTW its a 1989 Chevy 4x4 2500, had a 350. 454 engine from a 1993 K3500. using my 7747 with a chip from Brian set up for a 454. Re-used the CTS, MAP, dizzy, EGR, from the 350. Used TPS and IAC from 454.
The problem that im having is a erratic idle, hunts up and down, and a cut out when I blip the throttle from an idle. My initial thoughts were vaccum leak, but a quick test said probably not, but i do need to do a more thorough test. Timing is set to 4*BTDC.
Old Feb 3, 2010 | 01:38 PM
Re: 454 to 350 TPS/IAC matched wires by color(?)
i have found on pirate 4x4 this quote
"if the wiring harness is from a 350 then the wires on the TPS need to be switched. The dark blue and gray ones."
anyone confirm? would this cause my hesitation/stumble
Old Feb 3, 2010 | 04:18 PM
Ronny's Avatar
I posted my successful wiring of IAC from 350 harness to 1995 7.4L TBI unit with IAC in this thread.
https://www.thirdgen.org/forums/diy-...i-iac-7-a.html
Old Feb 3, 2010 | 09:40 PM
i did some checking tonight and the gray wire is 5volts ref, and the blue/white wire is .5 to 4.5 volts, transitions smooth. so i guess that rules out TPS from my problems. I suppose my next step is to check fuel pressure, vacuum leaks, and so on. Any hints on where to look? Any help is appreciated.
There is a thought in the back of my mind that perhaps the chip is at fault, but ill give brian the benefit of the doubt and check everything else first.
Old Feb 4, 2010 | 09:13 AM
Ronny's Avatar
A good chip the CE or SES, key on engine off, will blink and stay on. A bad chip or .bin with blink rapidly on same. you do have the CE light right?
MustangBeater20
Oct 29, 2022 09:20 PM
lee01
Apr 9, 2016 01:56 PM
sreZ28
Aug 14, 2015 07:48 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
