305 to 350TBI
Old Feb 3, 2010 | 05:40 PM
L98wit's Avatar
Car: 91 rs
Engine: 350 tbi with EBL
Transmission: t56!
Axle/Gears: 2.733
305 to 350TBI
so i decided to keep the TBI from my 305 to make life easier. i know that it should be a straight swap of intake manifolds and i have to change the PROM to fit my engine and injectors and prbly get a new fuel pump. what i'm wondering is what HP/torque specs would my car have if it would have two new 22ib injectors with updated PROM in a TBI L98? not exact but a good estimate? (i don't know much about engines but the L98 i'm swapping in is from a 92 camaro).
Old Feb 3, 2010 | 11:23 PM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
Re: 305 to 350TBI
Do you have any mods on the car? Headers, exhuast, etc? You will not need a fuel pump for the swap, just a chip and two 350 injectors. Rockauto.com has them pretty cheap. For the chip talk to Ryan harris over at TBICHIPS.com. Assuming no mods whatsoever and a stock 350 tbi chip...... probably between 280 and 320 horsepower. That's my best guess.
Old Feb 4, 2010 | 02:27 AM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Re: 305 to 350TBI
So a chip and two 350 injectors makes my slow 305tbi a 350 tbi?
Yes I am a noob And I'm sure i am a real dumbass right now
Old Feb 4, 2010 | 05:54 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: 305 to 350TBI
You will probably make better peak hp then the L98 camaro/firebird did, using LO5 injectors with a decent tune.
Are you planing a cam swap wile the engine is out? https://www.thirdgen.org/forums/tbi/...-ultimate.html
The 350 TBI injectors are 61, 65 and 68 lb/hr.
These 2 treads are wery helpfull, https://www.thirdgen.org/forums/tbi/...-350-swap.html
https://www.thirdgen.org/forums/tbi/...i-buildup.html
Old Feb 4, 2010 | 04:49 PM
L98wit's Avatar
Car: 91 rs
Transmission: t56!
Axle/Gears: 2.733
Re: 305 to 350TBI
thanks for all the responses. if i put new 68ib injectors in my car would i need a new fuel pump? if i do can i replace it with another in'line pump instead of an intank pump?
just want to make sure cause i will floor the gas pedal
Old Feb 4, 2010 | 04:59 PM
Car: 1992 Camaro RS
Transmission: WC T5
Re: 305 to 350TBI
You do NOT need a different fuel pump. The 4.3L V6, 305 TBI, and 350 TBI cars and trucks all used the same part number fuel pump.
You will need to tell whoever burns you chip exactly which ecm you have, the part number and size of fuel injectors, and what year/make/model engine you have so they can figure out which camshaft profile you have and thus which program to put in the chip.
Old Feb 5, 2010 | 11:17 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: 305 to 350TBI
I've got an extra LT1 cam if you wanna go that avenue, was gonna use it in my next build but im going LS for it instead
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
