Another camshaft question thread.
Old Feb 9, 2010 | 08:57 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
I am looking for a good cam for in the future with my build. I came across this http://www.summitracing.com/parts/EDL-3702/ and would like input.
I have a 89 RS 305 TBI. I will also be rebuilding, upgrading heads, intake mani.....ect. If I am not mistaken, I have a roller cam in the 305 from the factory. This plus many Flat tappet cams show up in the search for my car/engine. I am not going too aggressive just a mild I suppose.
Thanks in advance for any input.
edit: Just looking to get upwards of 250-300 hp, will be a dd in warmer months with a couple runs to the track, thats all.
Old Feb 9, 2010 | 09:12 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Another camshaft question thread.
I think you can't put a flat tappet into a roller
Old Feb 10, 2010 | 12:29 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
you can, in fact, many trucks set up for roller cams had flat tappets. it would be kind of a set backwards in one aspect though, to put a flat tappet cam in, when you already have the roller lifter with retaining mechanisms.
Old Feb 10, 2010 | 08:33 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I know you could but i meant that you would have to change the lifters too
Old Feb 10, 2010 | 09:14 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
That cam isn't bad, but you'd get the same power and probably better driveability with a LT1 or LT4 cam. Roller cams are superior in every way, and there's no reason to go backward technologically.
Old Feb 11, 2010 | 12:10 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I'm pretty sure you would also have to change the pushrods too if you went to a flat tappet cam. You should try and stick with a roller cam for sure. If you are on the cheap you can use a used roller LT1 like Saabster said otherwise I would look into a cam with a bit more intake duration, more lift and a tune. Comp and Lunati have same really nice stuff if your willing to spend ~$300 on one.
blackroc68
Sep 1, 2015 08:01 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
redmaroz
Aug 16, 2015 11:40 PM
