TBI Adjustable Fuel Pressure Range
Old Mar 2, 2010 | 01:28 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I've read the range on the stock regulator goes from 10-15psi. I can't get more than 12psi on mine.
Has anybody had a similar issue?
Old Mar 2, 2010 | 02:04 PM
Ronny's Avatar
Re: TBI Adjustable Fuel Pressure Range
It may be that is all it can do. Many of us upgraded to a Delco TPI FP. Threre is also a slightly stiffer spring available at topdownsolutions.
Old Mar 2, 2010 | 03:09 PM
Pukka's Avatar
Since I'm looking to eventually replace/rebuild my engine - could I still use a TPI FP and keep the fuel pressure within specs for my stock TBI?
Old Mar 2, 2010 | 03:22 PM
Ronny's Avatar
yes. your stock FPR will bleed off the excess pressure to gas tank. A Delco unit is highly recommended.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Infested
May 22, 2018 11:56 PM
pimp2303
Jul 27, 2017 02:03 PM
92camaroJoe
Aug 13, 2015 06:07 AM
