throttle issue?
Old Mar 6, 2010 | 12:55 PM
sk8r fer life's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
throttle issue?
ok so i got an 90rs, 305 tbi, you know the deal...when I drive the car and look at the rpm its reading around 3-400 at a stop and it feels like its going to die but never does. The fuel pump was just replaced and everything is connected correctly. My question is does the car naturally idle this low...and if not could this be the injectors? or throttle position sensor?
thanks tim
Old Mar 9, 2010 | 11:34 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Idle Chatter
Have you scanned it for codes?
Happy Racing!
Make Noise, Turn Left, Repeat
Old Mar 10, 2010 | 10:35 AM
Car: 1990 camaro rs
Engine: 305 tbi
Re: Idle Chatter
I haven't had any to my knowledge, its been like this since I bought it and it never gave codes...
Old Mar 11, 2010 | 01:22 PM
NINÅ's Avatar
Transmission: 765R4
Idle Chatter
A contaminated oxygen sensor can cause low idle.
I would look at it.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Mar 16, 2010 | 08:30 PM
Yuffie55's Avatar
Car: 1992 RS
Engine: 305 TBI
Transmission: 4L60
Axle/Gears: 2.77
Re: Idle Chatter
how low do it it ider at a stop is it a autoM if a AutoM i ider at 750 rpm a manel is the same i think check your ICV see if if dirt maybe time for a tbi Cleaning
Old Mar 25, 2010 | 03:04 PM
Car: 1990 camaro rs
Engine: 305 tbi
Re: Idle Chatter
I would look at it.
Happy Racing!
well I just replaced that, so I dont think thats the problem but you never know, and idles around 300-500 at a stop while in drive, and what is an autoM
Old Mar 25, 2010 | 04:24 PM
Ronny's Avatar
Re: Idle Chatter
autom=automatic
idle is controled by a metered vac leak. the iac valve needs to be looked at to see if it functions properly. you can see it by looking down the TBI unit. jumper the ALDL and you can cycle it with ign on engine off. It may be sticking or stuck closed.
theshackle
Sep 17, 2020 08:26 AM
Prodigious
Oct 4, 2015 11:20 PM
someone972
Aug 30, 2015 12:52 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
