Just mounted Edelbrock Open Element
Car: Firebird Formula
Engine: 305 TBI
Transmission: M5
Re: Just mounted Edelbrock Open Element
Hey daph, this is the cleaner right?
Clicky
Trying to make sure before I head and buy some things. Finally gonna get some floor mats!
Clicky
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Ok, so I can now say that my cars runs great with the new map sensor! Fuel consumption decreased noticably, the idle is great and everything feels much more in order!
I have now started taring down my A/C, since I'm planning on making my engine compartment cleaner and easier to overview. I'll upload some pictures tomorrow along with a couple of questions. Hope you guys can help me with this aswell
i wish i could tear out my A/C but it works too good lol, if it didnt work it would be gone
Clicky
Clicky
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Well I purchased it, and everything looks like it fits, hood clearance is a bit rough but its doable
There was 2 models actually at oreillys, one was $35 and the other was $39. I purchased the $39 model and everything fits well. One thing that im wondering is what are the 2 sets of predrilled holes for and the included T?
As for clearance everything is fine besides what i attached below, is the the spot where touching is a nono? wires dont look exposed and thats the only thing that seems to touch or might touch.
Engine: L03, LB9
and yes thats the "nono" aread for any metal to touch, but i didnt do anything to mine and its been fine for 3 or 4 years now, if you really want to do something about it wrap it with electrical tape and it should be fine
Mine has 2 Sets of holes on the bottom lid. Which seem to come off with a good pulling. The T I was talking about seems to let the IAT in perfectly. That might be it but I will take better pictures of it tomorrow morning.
Still was a very good purchase, I have to buy one of those filters to plug up the Thermovac hose or whatever its called that recirculates hot air to the air cleaner. One thing is, when I went to Autozone/Oreillys they seem to have a pre-hose installed to fit smaller hoses. Is that removable or does it just slip in the hose? Might pick it up this weekend.
Also for the little vaccumn line that went under the original cleaner, What would be a good way to plug it? Get a clamp and do it that way? I just taped it shut for now.
Engine: L03, LB9
any vacuum hose that needs to be capped off, unplug it from your Throttle Body and buy some vacuum caps from the part store and cap it that way, its the cleanest way to do it and it wont leak
You predicted my method! Saw some of those plugs at Auto zone and did that.
Also, Anyone try doing valve covers? I have been working on cleaning up my engine bay and the covers are really dirty, I want to pull them out and give them a good cleaning and a good paint job. I saw some chrome ones at Auto Zone that if I recall were center bolt, I might check them out next time I am there.
They are similar to these Part number #141-107 if the link does not work. They are the same but without the bowtie logo and are $68 if I recall.
Engine: L03, LB9
alot of people say if you buy valve covers dont buy cheap ones, they are too flimsy and will leak even with the best gaskets(i use rubber fel-pro's)
and remember before you put your covers back on(new or your stock ones) make sure they are as straight as you can get them, if there is even a slight bend its gonna leak
also when you take your old gasket out make sure you get EVERYTHING thats left over, i missed a tiny piece of old gasket and mine leaked.
and i Apologize to Daphi for letting this thread move away from the original intention, the way i see it now its turned into a "open element"/"clean my engine bay" thread
Haha im sure hes cool with it.
Well for the most part my engine bay is stock, all the smog things were swapped over to the L05. The engine only under 15, XXX miles if my math is right. I removed the driver side cover a good while ago and the gaskets I put on were still good but I had Felpros replacements just in case.
Also here are some pictures of my element, Forgot to post em up! Sorry but it was taken from my old phone.
Engine: 305 TBI
Transmission: M5
My delete pulley for the A/C compressor is now mounted and my god it's sounds beautiful without the noise from the old compressor. Now you just hear the engine idling quietly and nicely and the only noise comes from the double 3" exhaust
Everything works great and the car is 2 weeks from ready to roll! I'll post pictures when I'm completely finished with the car.Once again, thank you CaveCock for all the answers to my questions. And thank god for thirdgen.org
Buy a filter for it. I used a 19mm diameter filter for mine and it works great. It's not supposed to be plugged. You don't really need a filter, but it looks better and prevents "spills".
No problem at all! I'm glad my thread can help out other fellow firebird-freaks out there
Well today my throttle got stuck and I really don't know if the cleaner caused it. Just for precautions I let it have some of the bump space it has on the punch out circles. It scarred the **** of my uncle though!
Brinkkl2000
Aug 4, 2018 08:29 AM
86IROC112
Aug 17, 2015 02:00 PM
