305 w/L69 heads and cam?
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Open 2.73
Re: 305 w/L69 heads and cam?
Ok ,forget the cam, i found the heads though. I was needing to know if those heads will fit the intake on my 92 rs?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The L69 heads are from years '83 to '86, so they would have the '86 and older intake bolt pattern.
Your TBI intake is from '88 to '92, so it has the newer bolt pattern. No it will not bolt directly up. But you can grind open the center four holes to match. Whether its worth the swap is up to you.
84z96L31vortec
Aug 20, 2017 12:16 AM
ambainb
Apr 25, 2016 09:21 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
