is there any way to put a egr on a non egr intake?
Old Mar 17, 2010 | 05:27 PM
co15say's Avatar
i have done a vortec head swap on my truck but my intake is a non egr intake. i have noticed they sell spacers for fords where you can just mount the egr under the tb or carb. do they sell stuff like that for chevy tbi motors or does anyone know of a way to mount a egr to my intake? thanks
Old Mar 18, 2010 | 10:14 AM
Ronny's Avatar
Re: is there any way to put a egr on a non egr intake?
Did you check summit? I thought they had something that may work? Did you see a similar thread below?
Old Mar 18, 2010 | 06:41 PM
co15say's Avatar
i didnt see anything in summit or here.
Old Mar 18, 2010 | 10:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's no exhaust crossover on vortec heads, so even an EGR manifold wouldn't help. You'll need to do some creative plumbing.
Old Mar 19, 2010 | 01:11 AM
co15say's Avatar
how? and also i do still have the vortec driver manifold if that would help. is there anyway to do it?
Old Mar 19, 2010 | 09:13 AM
Ronny's Avatar
I would check GM Performance Parts.
Old Mar 21, 2010 | 12:29 AM
89junkyardgta's Avatar
Car: 1989 GTA, 1985 T/A
Engine: L98, LG4
Transmission: Slush-o-matic 700R
Axle/Gears: stock and stock
Yes, you can plumb in an external EGR, however, I don't know how it will work with your emissions and computer, etc because I have no idea where the apropriate place to pump the gases to would be. I would guess just under the TBI (like the F*rd plate you mentioned) would probably work, but I couldn't say for sure. I *think* the TPI or LT1 Corvettes had a totally external EGR valve. I wouldn't bother using the vortec exhaust manifold. Just get headers and weld a bung to them and pipe the exhaust gas to the valve, then the valve into the intake. You're going to have to do a bit of research, but I think it can be done.
Old Mar 21, 2010 | 12:47 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
I take it you're trying to comply with emission laws... there's a possibility that it will be identified as a tampering act and will fail your test...
Old Mar 21, 2010 | 08:16 AM
co15say's Avatar
thanks for all the info guys
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
drathaar907
Aug 6, 2015 04:20 PM
