Car won't start
Old Mar 28, 2010 | 01:21 PM
Xgallegos4's Avatar
Car won't start
I have a 1990 rs with a 305 and it won't start I changed the fuel filter bought a new battery but when I spray starting fluid it starts but then shuts off what's wrong with it? Any help is appreciated
Old Mar 28, 2010 | 03:48 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Car won't start
1990 RS is not carbed from the factory - they are TBI cars (Throttle Body Injection - kinda looks like a carb, but has fuel injectors inside). Is it a carb or a TBI?
Is the fuel pump coming on when you turn the key on? (you should here it whine from the trunk area). If no fuel pump whining, replace the fuel pump relay.
Old Mar 28, 2010 | 03:56 PM
shadowknight's Avatar
Car: 89 rs
Engine: 305 tbi
Axle/Gears: stock
Re: Car won't start
your not getting fuel. listen for the fuel pump when you turn the key on. you should hear a wine comming from the trunk area. if you dont hear it try removing the relay and testing it. if the relay checks out ok then its most likely your fuel pump. hope this helps
Old Mar 28, 2010 | 04:11 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Car won't start
make sure you check the relay harness to make sure that power is getting from point a to point b...
Old Mar 28, 2010 | 08:50 PM
Xgallegos4's Avatar
Re: Car won't start
My mistake I though it was a carb but it's 100% stock so it's the tbi do they get clogged easy could it be the tbi? I haven't check if the fuel pump is working or not but I will
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
