T.B.I. Injectors help
Old Mar 29, 2010 | 09:32 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I only have one working injector. The drivers side injector only sprays on start up. Everyone tells me it could be something other than the injector but no one has been clear on what it could be.
I am trying to find out what EXACTLEY I should look for or test for? Or should I just buy a new injector and be done with it?
Seems to me if it is spraying momentarly on start up then it can't be the electrical connector or the fuse.
Is there a fuse somewhere other than in the fuse box I should be looking for?
Thanks in advance.
Old Mar 29, 2010 | 10:05 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: T.B.I. Injectors help
Seems to me if it is spraying momentary on start up then it can't be the electrical connector or the fuse.
Thanks in advance.
You'll have to do a bit of troubleshooting with DVM or a test light. Basic injector circuit is very simple:
One side of injector is tied to ignition +12 volt source and the other is pulled by ECM to ground to close (fire) injector. TBI injectors have low impedance coil with DC resistance measured around 1.0 to 1.2 Ohm (with 2mH inductor in series). This requires circuit inside ECM to be able to pull down momentarily up to 4 Amps, but once injector is actuated (open and delivering fuel) holding current can be reduced down to 1.5Amps or less. Enough of theory.
1) Check injector coil resistance with a DVM. This might be tricky since contact resistance between test leads and injector terminals might be high. But try getting a good contact - look for 1.1 to 1.5 Ohms on your DVM. If one significantly different from the other you found your dud.
2) Check voltage presence with engine running on both "A" terminals. Terminal B is the ECM side and a test light should be flickering. With engine stopped, ignition on both terminals (A & B) should be around 12 volts.
3) Once you figure which injector is not firing verify that 12 volt is present at the respective ECM header pin ( Either D16 or D14) If there is no 12 volts at ECM and Pin B is at 12 Volt check circuit 467 or 468 for damage.
4) If there is 12 volt present at D16 or D14 then injector driver circuit inside ECM has been damaged (switching transistor has been zapped or there is an open trace some where on PCB)
//Alex
Old Mar 29, 2010 | 10:55 AM
Axle/Gears: Posi
Thanks Alex
Old Mar 30, 2010 | 12:09 AM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
if not , try witchunterperformance they do a great job @ cleaning injectors .
Old Apr 17, 2010 | 02:23 PM
db660r's Avatar
i had the same problem with my firebird. i just ran the red to the white so they both had 12 volts and they fire eveytime. might not be the proper way but it will work till i get a ecm
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
