Engine surges irraticly!!
Old Apr 9, 2010 | 09:16 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
In my '88 S/C with an L03 my engine runs fine most of the time, but sometimes when it starts my engine idles from about 500rpm to 1000rpm and tries to die. Then it starts to die as soon as I shift into reverse as well. Once I get back into drive my engine surges and car barely moves. After about five minutes of this she finally starts to run right, any ideas? I have no idea where to start and I'm tired of being late for work due to this problem.
Old Apr 9, 2010 | 09:52 PM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
Re: Engine surges irraticly!!
i think i know what your talking about. im having that problem now too if its the same. my car runs normal then it dies once i start it again it runs 400rpm to a 1000rpm and it sounds like a badass with the whining it makes but when i rev it it just dies. i adjusted my timing a little bit advanced and it seems to be running fine now try that
Old Apr 9, 2010 | 10:14 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'd check the codes and see if anything comes up.
Old Apr 9, 2010 | 10:35 PM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
i will have to do that. can i buy that code reader at a parts store or do i have to order it
Old Apr 10, 2010 | 09:14 AM
Car: 1992 RS
Engine: Carbed 350
Paperclip is your best friend - keep one always in the center console for this:
https://www.thirdgen.org/service-eng...ht-error-codes
Old Apr 10, 2010 | 12:01 PM
Engine: 350 S/B
I have a twelve pin connector but only have wires in the following locations: 1,2,4,5,6,7,12. I tried to jump from 6 to 12 and got nothing but two flashes from my S.E.S. light. Did I do it wrong or will it not work for my car. What other way can I get these codes to show up?
Old Apr 10, 2010 | 10:14 PM
Car: 1992 RS
Engine: Carbed 350
Maybe you just didn't get it right - try again. It's slow, so patience is in order.
Jump 6 and 12.
Turn key to on (not starting).
Watch the SES light - it will flash once, then twice, then pause, then repeat, then pause, then repeat - this is code 12, which means it's in diagnostic mode.
Then it'll pause again.
Then it'll flash codes, for example it'll flash 3 times, then 5 times, then pause, and repeat - this would be code 35 in the chart.
It flashes each code 3 times, then moves to the next code.
When all codes have been displayed, then it'll do the 1 2 code again 3 times.
Old Apr 12, 2010 | 08:08 PM
Engine: 350 S/B
O.k. I jumped from 6 to 12 and when I turn my key to the on position my service engine light flashes twice then stops. That is all it does. I watched for about five minutes and it does nothing....WTF?
Old Apr 13, 2010 | 03:48 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Did u check FP (fuel pressure)?
Old Apr 13, 2010 | 06:31 PM
Engine: 350 S/B
I haven't checked my fuel pressure. What's the easiest way to do this?
Old Apr 14, 2010 | 03:53 AM
thomas1976's Avatar
Car: 91 Trans am
http://www.actron.com/product_detail.php?pid=16175 With the engine off, its easy to put on the fuel feed line (the one on top) right next to the alternator.
Old Apr 20, 2010 | 07:10 PM
Engine: 350 S/B
How far did you advance your timing GND-646?
Old Apr 21, 2010 | 10:58 AM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
i havent been able to fix it now it just idles and pops i cant find out whats wrong i changed all plugs and plug wires but it still misfires
Old Sep 5, 2010 | 08:11 PM
Engine: 350 S/B
TTT
Old Sep 6, 2010 | 11:54 AM
Engine: 350 S/B
Ordered a fuel pressure gauge today. Hope that helps.
Reddeath210
Oct 6, 2015 08:20 AM
jbd1969
Aug 17, 2015 07:06 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
