TBI to TPI
Car: 84 Z28, 89 RS
Engine: 305 ho carb,305 tbi
Transmission: T400, 700R
TBI to TPI
i have an 89 rs and have in mind a 383 for new motor. it currently has a 305 tbi i was wondering it there is that much of a hp difference to upgrade from tbi to tpi or if it would be just as good to leave it or put a carb on it? Also if anyone happens to know this would also be helpful. can you reuse a vaccum secondary distributor from a carb 305 on a carb 350?
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
Re: TBI to TPI
I pulled my TBI engine out, converted it to TPI w/ an LT1 cam in it, and I gotta say it hauls *** like it NEVER did before
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: TBI to TPI
NO
you upgraded a big improvement over TBI { now I might get remarks }
is that what you think we do?? in here... is post sarchasm?
TPI has the best bottom end.. you can find in any intake combo
Car: 1992 Camaro RS Convertible
Axle/Gears: LS1 posi/disk 3.42
Re: TBI to TPI
Did u do any tuning or just used the stock tune? I have an lt1 cam and a tpi setup im waiting to install. Just need the time and some new valve springs
Re: TBI to TPI
stock tune on an 87 MAF TPI setup, the MAF will compensate for the increased air flow, though I can benefit from a tune...
Car: check
Engine: check
Transmission: check
Re: TBI to TPI
It also sounds like there may have been other changes to the engine while it was out?
When several changes are made to an engine at the same time, one can't put all of the gains on one of the pieces. It is all of the items that made the difference.
RBob.
evilstuie
Jan 9, 2020 08:29 PM
Sanjay
Aug 12, 2015 03:41 PM
