what are good heads for a tbi
Old Apr 19, 2010 | 04:41 PM
91maroRS91's Avatar
Car: 1991 Camaro RS, 1987 Firebird
Engine: 305 TBI, 350 TPI
Transmission: 5 Speed, Auto
Axle/Gears: N/A someoone tell me
im looking at buying new head for my camaro. i have know clue what good heads i could buy to put on. its a stock 305 tbi. im gonna start moding the engine but id really like to know what kind of heads i should get. can someone help me out let me know what kind of heads would be good.
Old Apr 19, 2010 | 05:45 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: what are good heads for a tbi
TFS 175 56cc, could probably be the best direct replacement for a LO3. Though rpm limit of a stock bottom end may limit the potential, some.
I would look in to a cam swap at the same time, if possible.
By swapping heads, the piston to head clearence will end up being on the big side, without milling the deck of the block.
Old Apr 19, 2010 | 06:11 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
unless you have bigger plans.. a 900.00 pair of trick flows..
could buy many upgrades like gears, headers, exhaust,performance cold air setup
maybe a cam
Old Apr 21, 2010 | 01:10 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I'm putting on a set of ported ZZ4's soon. From what I've read they work fairly well
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
dutch930
Sep 11, 2015 06:58 AM
db057
Aug 22, 2015 08:17 PM
InfinityShade
Aug 22, 2015 08:00 PM
