I have L03 heads...
Old Apr 20, 2010 | 11:12 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
I have L03 heads...
I have L03 heads on my 88 TPI 305 running a 94 LT1 Cam w/19lb injectors.
This was at ONE point in time a bone stock 305 service block with L03 heads, cam, and injection. since the engine only had about 5k on it, I topped it off with LT1 cam, behive springs, and TPI setup. the damn thing has some ***** on it, thats for sure. but i'd LIKE to give it a little more, which brings me to the point of this thread, 1.6 roller rockers.... bent valves and terrible valve cover clearance? or go for it you'll love em? which will it be?
Old Apr 21, 2010 | 05:19 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: I have L03 heads...
I agree, the LO3 with LT1 cam slips in the fun category.
If you have the .450/.460 lift LT1 cam, with the 1.6 lifters that will be .480/.490 in. The stock 187 heads should have a .470 safe limit.
But you should be fine with LT4 style valve spring retainers. Try a little search.
One thing that comes to mind, is that the 187 heads flow capability don't appear to take full advantage of the LT1 cam, so adding 1.6 rockers may end up not meeting big expectations. Though I have not tried and cannot tell for sure.
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
anesthes
Sep 21, 2015 10:24 AM
Chrome
Aftermarket Product Review
Sep 25, 2001 09:02 PM
Sharpcorner
Jun 14, 2001 12:58 PM
