lost firing order
Old Apr 26, 2010 | 03:16 PM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
lost firing order
i have a bit of a problem when i was replacing plugs i didnt mark number 1 and i lost its location on the distributor the firing order is 18436572 but i dont know how to find number one on distributor. any ideas on how to help me
thanks
Old Apr 26, 2010 | 03:37 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: lost firing order
Do you not have any plug wires on? If not, then you will have to find #1 this way.
Pull #1 spark plug out. Have someone bump the motor untill you feel air being PUSHED out (disable the car somehow so it will not start). When you feel air come out, turn the motor by hand till your timing mark on the balancer lines up with the tab on the timing chain cover. Then pull the cap off and see where the rotor is facing. Mark this somehow and when you put the cap back on, this is going to be your #1 plug. The rest go on in the firing order counterclockwise.
Old Apr 26, 2010 | 03:40 PM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
thanks. and you have a real nice looking engine
Old Apr 26, 2010 | 03:41 PM
built91Z28's Avatar
Thank you.
Old Apr 26, 2010 | 04:02 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
See that line on the top of the dizzy that is centered with the coil post. To the left of that line going clockwise is 21843657.
If using a stock cap there will be two lines, one facing the driver door about (as shown above) and the other 45* to the strut tower. Let me know if you need a small video or something to make it easier.
Old Apr 26, 2010 | 04:30 PM
built91Z28's Avatar
That could work assuming that every previous owner has put the plug wires back on the same way.
Old Apr 26, 2010 | 05:49 PM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
thanks and dont want to be a pain but could you do the video thing. im good with engines just not with distributors and the ignition. also on my stock cap could you tell me where the hold down bolts are
KCG
Jun 24, 2020 04:33 AM
camarohelp
Sep 22, 2015 03:19 PM
sahlomonic
Sep 20, 2015 07:15 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
