Trick Flow Fuel Pressure Regulator
Old May 6, 2010 | 12:38 PM
Shakermaker05's Avatar
Car: 1991 RS
Engine: 305 LO3
Axle/Gears: 2.73's : (
I can get this FP Regulator for 75 bucks. Will it work w/ an LO3?? Product discription says it's for Fuel Injected cars and is universal, but for multiport injection so I was unsure. Thanks in advance!
LINK http://www.summitracing.com/parts/TFS-5158REG1/:
Old May 6, 2010 | 01:59 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Re: Trick Flow Fuel Pressure Regulator
does not look like it would fit at all.
Old May 6, 2010 | 03:49 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
that wont work on your tbi setup. the used to be a write up around here that shows you how to turn your stock fpr into an adjustable one with one bolt and a tap/die set. save yourself $70 and do it yourself with a stock piece
https://www.thirdgen.org/forums/tbi/...-pressure.html
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
89-S-dime
Aug 12, 2015 11:57 AM
