How to clean EGR valve????
Car: 1989 Camaro RS
Engine: 305 TBI
Re: How to clean EGR valve????
I have cleaned a few. Take it off the car and Just spray some carb cleaner in it. Let it soak inside for a while. Then press on the diapham to see if it is moving. At least it is cheep and simple to try brfore buying one. Is it sticking? What problems are you having?
edit: Also, while it is off spray some cleaner in the egr ports on the intake and scrape with a wire brush or screwdriver.
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
My engine surges badly at times and almost dies. Most of the time it happens in reverse. Especially when it's cold.
Engine: 350 S/B
It may very well be a vacuum leak. When I bought the car I had found a couple lines disconnected and had to hook some up to get my A/C and heater to work as well. Any vacuum diagrams on here?
Car: 89 Camaro RS
Engine: Built 357 Vortec
Axle/Gears: 3.23 from an '87 iroc
mdtoren
Aug 16, 2015 05:45 PM
