parts list for stock 305
Old May 26, 2010 | 10:38 PM
bduffey723's Avatar
Car: not a camaro anymore
so ive decided to gather a summer parts list for my not fast 305. tell me what you think
Bolt-on Barrage Shopping List
MFG
Part Number
Description
Edelbrock
5673
Cat-back exhaust system
3701
Performer manifold (EGR)
68743
TES Headers, Ti-Tech finish Four-bolt flange I-pipe, 3-inch diameter
MSD Ignition
84111
Extreme Output distributor cap
84101
Extreme Output Rotor
31459
Super Conductor Wire Set
Trick Flow Specialties
TFS-30300002
23-degree, 175cc Small Chevy Heads w/ 1.47-inch spring upgrade
TFS-31400511
3/8-inch stud-mount roller rocker arm set
TFS-31478500
Billet timing set
TFS-21407850
chrome-moly pushords, 7.850 inches
TFS-31400915
engine gasket set
TFS-K3140100
SBC cam and lifter kit (hydraulic flat tappet)
Old May 27, 2010 | 09:00 AM
bduffey723's Avatar
Re: parts list for stock 305
nothin?
Old May 27, 2010 | 04:59 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Best is you add the liks of your parts directly in your tread. Will make it easyr, quicker and more accurate.
At first wiew there are some details.
Edelbrock headers are among the less performance oriented, could add the billet timing cover budget for better headers. http://www.top-downsolutions.com/pro...bdeb6b1fd933ab
MSD parts you posted are probably all useless, pick a set of wires with only 90° sparkplug connectors, for headers and specially angle sparkplug heads.
Kinda hard to tell pushroad lengt without mesuring.
Heads gasket should be choosen to give a resonable quench, mesure piston to deck first.
You will need.
Higher flowing fuel pump http://www.tpiparts.net/inc/sdetail/688 or similar.
VRFPR http://www.turbocity.com/product_inf...roducts_id=602 or similar.
Tune your set up http://dynamicefi.com/ this is probably your best option.
Old May 27, 2010 | 08:58 PM
bduffey723's Avatar
so i have a new problem...
im juss cruizin down the road goin about maybe 50 and car shuts off.. throw it in nuetral turn it back on runs great for about 10 mintues and does the same thing.. so i brought her back home and dnt wanna drive her til i rlly f**k something up..
any ideas? maybe throttle sensor?
Old May 28, 2010 | 11:06 PM
bduffey723's Avatar
haha.. fuel pump..
Old May 29, 2010 | 04:55 AM
thomas1976's Avatar
Car: 91 Trans am
Your plans require more fuel and higher fuel pressure, so that pump needs to be replaced anyway.
1992 Trans Am
May 10, 2023 07:19 PM
Linson
Aug 21, 2015 02:12 PM
marcusaw
Aug 10, 2015 08:13 AM
1nastygta
Aug 8, 2015 07:38 PM
Leggman1
Aug 6, 2015 04:15 AM
