Intake manifold fitment question
Old May 30, 2010 | 11:45 PM
my89's Avatar
Car: '89 Formula
Engine: 305 TBI
Quick question- the intake manifolds by Edelbrock, Holly, or Wiedand: do they require machining of the bolt holes to fit onto stock '89 305 tbi heads?
Old May 31, 2010 | 04:13 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Intake manifold fitment question
What part numbers are you looking at? Generally the ones for 87-92 would not require machining.
Old May 31, 2010 | 04:32 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
If your using a true tbi intake no. If your used a carb intake with adapter, yes. Professional Products is the only company I know of that offer a carb intake for use with tbi heads.
Old May 31, 2010 | 10:42 PM
my89's Avatar
Car: '89 Formula
Engine: 305 TBI
So I'm asking because someone is selling an Edelbrock intake 2101 that they said they had drilled to accept the 1081 heads of their '87 IROC. I thought that intake should be a direct bolt on?
Old Jun 1, 2010 | 10:47 AM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
the 2101 is a carb intake. An adapter will be needed to place your tbi on top.
If you go with-
http://www.summitracing.com/parts/PFS-52001/?rtype=10
It has "bungs" supplied that will allow you to bolt right in. It will save you time in grinding.
you will still need-
http://www.summitracing.com/parts/TRD-2211/
to bolt your tbi onto.
Old Jun 1, 2010 | 10:05 PM
my89's Avatar
Car: '89 Formula
Engine: 305 TBI
besides the extra gasket, is there any downside to running a carb intake with a tbi adapter? Or is the Edelbrock TBI intake really good?
Old Jun 2, 2010 | 11:24 AM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
I've never used the edelbrock tbi unit. I just wasn't willing to pay over 250$ for an intake. Carb intake + adapter = 180.00.
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
