need help with 88' 454
Old Jun 2, 2010 | 05:46 PM
ShaneJ's Avatar
Helping out a friend with his 88' k3500 gmc. it has a 454 tbi . it is spark knocking excessively, and timing will go to 41 degrees when the motor is revved(granted no load). There is no knock sensor or esc module on this truck.If it is they hid it but good(not on the right hand block side). Would GMC have put this together without a knock sensor? what would control timing? It has been on a scan tool ,both the map and o2 sensor needed replaced. after replacement there was no change in the spark knock condition. Need help from the guru's ! thanks in advance.
Old Jun 3, 2010 | 12:53 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: need help with 88' 454
You probably have 1228747 ECM with HD emissions. HD application (454) have been known to omit ESC and KS. From your description it appears that base timing is incorrect. Almost all truck application call for 0 deg base timing with EST connector disconnected. After setting base timing turn off engine - disconnect battery for 30 seconds to clear EST code. HD timing is very conservative - this way KS is not required.
For more information check with boys on http://67-72chevytrucks.com/ or FSC
http://www.fullsizechevy.com/
//RF
Old Jun 3, 2010 | 09:23 PM
ShaneJ's Avatar
RFmaster, Thanks for the info. He went back over everything and did find the base timing was off.
MustangBeater20
Oct 29, 2022 09:20 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
