new injectors or new o-rings?
Old Jul 6, 2010 | 10:31 AM
Theman0188's Avatar
Car: 76 Corvette Stingray
Transmission: TH350
Axle/Gears: Stock
I have a 92 firebird with an lo3. I have been searching for my running rich issue for a while and i finally watched the injector flow they both aren't spraying a uniform cone spray. the passenger side is worse than the driver side, but how do i tell if the injectors themselves are bad or if i just need new o-rings?
Old Jul 6, 2010 | 11:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: new injectors or new o-rings?
Key-off, engine-off, jumper fuel pump on (pigtail near relay), and observe the injectors. Any fuel leakage and it needs o-rings. It is rare for TBI injectors to go bad or get clogged, but it can happen.
RBob.
Old Jul 7, 2010 | 11:52 AM
Theman0188's Avatar
Transmission: TH350
Axle/Gears: Stock
Thanks for the help RBob, I don't think the injectors are clogged because they are both spraying consistently just dripping a little within the cone spray. I haven't got a chance to test them the way you stated, but I should get a chance this weekend
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
BOOT77
Sep 16, 2015 08:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
BOOT77
Sep 5, 2015 03:55 PM
