hey
Old Jul 9, 2010 | 08:38 PM
Matt S iroc's Avatar
hey
i swapped out my trottlebodies yesterday cause the butterflies stick on the original one.i first tried cleaning it,that didnt help then i tried alittle sanding and that didnt help.so i just figured id swap them.it runs alittle better with that one on it but,now it doesnt want to shft into second till its running about 25 mph.shift into 3rd about 40-45.what is causing this and what can i do to fix it?it shifts way too hard and im afraid that ill ruin the transmission.PLEASE HELP!
Old Jul 9, 2010 | 09:17 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: hey
When you swapped TBI units make sure that your transmission linakge did not get hung up on anything. It is easy to do. Also, a few squirts of WD40 or equivalent should free up that throttle spring. Hit it with a wire brush first and it should free it up.
Old Jul 10, 2010 | 09:52 PM
Re: hey
the sensors on the tbi was the same but the three prong plug is facing up unlike the stock one which was facing to the passenger side.could that have anything to do with it.im guessing that those are the tps and the iac,so i doubt it,atleast thats my guess im knew to the tbi!
Old Jul 12, 2010 | 05:02 PM
loudpedal's Avatar
Car: DAF
Engine: 3 cyl 2 cycle
Transmission: variable speed
Re: hey
does the TB have the same hose ports as your original one?
check for proper base gasket and seal
the TPS should be ok vertical or horizontal style.
put your known good IAC in the "new" TB
At the end of the day, relook at your "old" TB and find out the problem and fix it.
Old Jul 12, 2010 | 05:15 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: hey
was the linkage exactly the same length. was it off another third gen or a totally different vehicle. the should all be near the same.
Loudnproud86
Jul 14, 2016 12:59 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
Zane Story
Oct 8, 2015 12:40 PM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
Keiffer76
Sep 9, 2015 08:52 PM
