is this cam too much for my l98 bored .060 over?
Old Jul 10, 2010 | 04:22 PM
Manic_Mechanic's Avatar
http://www.summitracing.com/parts/CCA-08-500-8/
*l03* my bad lol
summit recommended this cam but im worried about it running lean
seeing as i just rebuilt this motor its the last thing i need for it to bloww due to lack of fuel
Old Jul 14, 2010 | 04:10 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: is this cam too much for my l98 bored .060 over?
Thats a fairly mild cam. Aside from the mechanical considerations, such as whether the heads are up to running the lift provided by the cam, you will want to do some tuning. But, the cam should work very well with TBI. It doesnt have a lot of duration and relatively mild overlap.
Old Jul 14, 2010 | 04:13 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Also, what kind of heads do you currently have on the motor? Are they set up for more lift? That cam has close to .5" of lift, which is quite a bit. It will also want better springs than stock due to the more aggressive profile. If your running stock L03 heads, that cam wont help performance very much due to the limitations in flow. That cam is best used with heads like vortecs and others that have good flowrates at higher lifts.
lt500r55
Sep 1, 2021 01:30 PM
angel2794
Sep 8, 2015 06:22 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
z28guy134
Sep 1, 2015 11:50 PM
gixxer92
Sep 1, 2015 04:32 PM
