car surging while driving in overdrive??
Old Jul 28, 2010 | 09:06 PM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
I have a 1992 Pontiac Firebird convertible that has a 305 tbi with an 700r4 and has 2.73 rear gears and when im in overdrive at about 20-50 mph that car likes to kinda surge like it may have a slight miss or like it wants to down shift but its very slightly feeling when it does it but im still able to get 24 mpg in it.
Any thoughts of what it could be?
Old Aug 6, 2010 | 10:10 PM
Engine: 5.0 TBI
Re: car surging while driving in overdrive??
bump
Old Aug 7, 2010 | 12:00 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Could be the torque converter locking and unlocking - they call it 'hunting'. Although the TC can lock in 3rd, you might try using D instead of OD and see if it makes any difference - if it seems to, then might just be that - check tranny fluid level - it might 'hunt' if the fluid level is low.
Old Aug 24, 2010 | 09:03 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
FYI, I had an 87 Chevy Silverado that was going in and out of lock up. I discovered when I held the break peddle out with my foot, the tranny would stay in lock up. I had a mechanic friend tell me it was the switch hooked up to the break peddle. When you apply the breaks, the tranny will unlock. Before I knew the problem I thought the tranny was flyin south.
Old Aug 24, 2010 | 11:05 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Does the tach read steady when it's doing this?
Old Aug 25, 2010 | 03:28 AM
No. The tach will show a slight difference. I think it's about a one and a half thousand difference. I'll have to check the revs when it locks up.
Old Aug 25, 2010 | 10:11 AM
Engine: 5.0 TBI
When my car does it, my RPMs rev up and down about 200-300 rpm until I press on the gas harder then it doesn't do it
Old Aug 25, 2010 | 10:17 AM
I think that's what mine reved when It was slipping in and out of lock up. I wrote that message in the middle of the night and half asleep. It sounds like your tranny is going in and out of lock up alright. Try driving and holding the break peddle like I did. It wouldn't hurt to try.
Old Aug 25, 2010 | 10:32 AM
Just for the heck of it, try driving and pressing lightly on the brake peddle while driving. This will cause your tranny to unlock, and it will go back into lock up. See if the rpm change is the same as your surging problem. I am going to drive my RS today and I will do the same to see the rpm difference. Let me know what you discover.
Old Aug 25, 2010 | 01:44 PM
Engine: 5.0 TBI
What do you mean by holding the brake while driving? What causes my tranny to lock in and out?
Old Aug 25, 2010 | 01:50 PM
What I mean is, the tranny will go out of lockup when you press down on break. Try it. After the tranny is nice and warm go out and drive it and watch your tach when you break. Do this at about 40 mph in D. Not enough to feel breaking, and see if your revs are the same as the issue you have. When you do this, keep your foot on the gas peddle.
Old Aug 25, 2010 | 01:57 PM
Engine: 5.0 TBI
Yes mine does that... what causes this?
Old Aug 25, 2010 | 02:11 PM
The lockup is just for cruising. When you break or accelerate, it goes out of lockup so the tranny is not under undue strain. Is it the same rpm range as the problem you have been having?
Old Aug 25, 2010 | 02:21 PM
Engine: 5.0 TBI
yes it surges at aroung 1400-1600 rpm but it does it in 2nd, 3rd, and overdrive.
Old Aug 25, 2010 | 03:11 PM
Is the surge the same rpm as the problem?
Old Aug 25, 2010 | 03:29 PM
Engine: 5.0 TBI
yes
Old Aug 25, 2010 | 04:40 PM
Well then it sounds like your torque converter is going in and out of lock up. I was told the 700r4 is not supposed to lock up in 2nd, but mine does. If I cruise in 2nd for a while, it locks up.
As with your issue, probably something simple like the switch the break peddle engages. I wish I knew more about where it is located.
Old Aug 25, 2010 | 08:01 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The 700R4 with an EFI ECM will lock up in 2nd (and 3rd and 4th). It is only 1st that the 700R4 can not lock up in. The 1st gear no lock up is due to the transmission circuits. No feed to the TCC when in 1st.
The TCC brake pedal switch is at the brake pedal. There is also a cruise control switch if the car is so equipped. The TCC switch is doubled up with the brake light switch. To adjust both switches (CC & BRK/TCC) , just push them forward until the outer plastic piece touches the brake pedal arm.
If need be pull the brake pedal towards the rear of the car and hold it while doing this adjustment.
The TCC lock/unlock can also be caused by a bad connector at the tranny.
RBob.
Old Aug 25, 2010 | 08:10 PM
I wanna thank you for the info RBob. I was told by a tranny rebuilder that the r4 didn't lock up in 2nd gear.
Old Sep 6, 2010 | 01:24 PM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
where on the transmission is the TCC connector, because an Iroc im workin on is locking and unlocking, and the two switches that touch the brake pedal are already makin contact with the pedal
Old Sep 6, 2010 | 06:28 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Left side, above the pan rail.
RBob.
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
86IROC112
Aug 17, 2015 02:00 PM
