A little Lo3 fun....need some info
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Been searching and refreshing myself with my 92 RS 5spd and I would like some help picking parts for a top end rebuild since this car has a blown head gasket and the a**hole who did it offered to pay for full repair.
what head/intake/cam make for a good TBI build for a little fun?
oh and im sick of 4k shifts so the more the better
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: A little Lo3 fun....need some info
You are very limited with the TBI computer. You could do a LT1 cam swap, and maybe an intake upgrade - but you do head swap and your gonna need custom chip tuning. You be better off doing exhaust. There's just not much can be done with the TBI chip in stock form - it sees too much increase in air and it just dumps fuel on top of it, making it run worse than ever (been there, done that).
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
There is a lot of options if you are willing/capable of tuning. You will need fueling upgrades as well to make more power.
It really depends on what your budget is.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
If you're on a budget just port the stock heads, get a 3704 intake off ebay and have the holes bored and slightly radiused with an LT1 cam. With some 3.73's, a posi and a tune it should be quite the peppy little motor.
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
it currently has the edelbrock headers with a large flowmaster (dunno exact size but larger than 3") but im going with new headers.
I am capable of tuning but really not willing to on this engine but I will most likely port the heads and go with intake and lt1 cam. I have never ported a v8 head but I have plenty of experience with rotary/60v6 so anything I need to look out for?
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Here's a thread about how to port if not he could port the
for you too https://www.thirdgen.org/forums/engi...sbc-heads.html
Car: 1992 RS
Engine: Carbed 350
Don't waste your time - the 305 TBI heads are best made into boat anchors.
If you do an intake and a LT1 cam and already have exhaust, your already pushing your luck - going to be getting dangerously close to overstepping the bounds of the stock TBI chip and getting into custom tuning territory to just get it to run at all.
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
so should I just look into a 350 tbi swap? I was a little worried about it since I have a t5 and not enough money for a t56 swap
Car: 1992 RS
Engine: Carbed 350
You could - alot of folks are fine with the T5 as long as they don't get crazy - could probably get by on the T5 until funds come along for the T56. I think you need the 350TBI ECM chip (from a Caprice or truck) and a 350 knock sensor - I'm not real familiar with the 350 TBI swap.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
There is a sticky in the TBI forum it tells you exactly what you need for the 350 swap
3rdgenparts
May 21, 2016 11:50 PM
Linson
Oct 1, 2015 09:50 PM
