305 tbi problem
Old Sep 3, 2010 | 03:55 PM
nick johnson's Avatar
Car: 91 camaro rs
Engine: 305 tbi
305 tbi problem
Hey everyone its my first time posting here. I love these forums and you guys are very helpful. Anyway, i have a problem with my 91 camaro. Only one jet is working on the tbi, and it must be an electrical problem as when i added power to it it jetted fine. One side is working fine, but the car barely runs at all now. I'm pretty sure this is an electrical issue but I have no idea where to begin fixing it
Any help would be very much appreciated!
Old Sep 4, 2010 | 03:57 AM
madmike1989rs's Avatar
Re: 305 tbi problem
maybe the plug ins on the injectors
Old Sep 4, 2010 | 05:40 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: 305 tbi problem
Check Injector coil resistance it should be around 1.0 to 1.2 Ohms. Like rs says check your injector plugs. Also, with engine off, ign on measure voltage at connector terminals - should be around 11.5 -12.0 volts at both pins.
//RF
Old Sep 5, 2010 | 01:27 AM
Car: 91 camaro rs
Engine: 305 tbi
Re: 305 tbi problem
ok so i put a new pump and relay but still have the same problem/
Could it be that the injector itself went bad?
and as far as checking resistance i'll have to get back to you on that one
Old Sep 5, 2010 | 11:18 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 305 tbi problem
that's why he is saying to do the tests on the injector. that doesnt cost money. changing a fuel pump does, especially when it wasnt in any way a bad fuel pump
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
