High HP TBI
Old Sep 15, 2010 | 01:21 AM
rscamaro305's Avatar
High HP TBI
What do you guys recommend? A performance engine using a modified TBI setup do the carb rules for the intake manifold still apply? Dual plane for low end and single plane for high end or do TBI motors prefer one over the other? Thanks
Old Sep 15, 2010 | 07:29 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: High HP TBI
"EFI Made Easy"
The New Holley Avenger EFI system is intended for users who want a "Bolt on and Go" EFI system without the need for a laptop computer! Avenger EFI systems are perfect for performance street engines, most crate engines and mild street / strip applications. Simply bolt on an Avenger system, answer a few easy questions and go! No laptop, no tuning, no fear!
A few features of the Avenger EFI are:
  • Self-tuning fueling strategy tunes while you drive - Designed for the user that wants ease of use without having to be a "tuning expert"
  • Requires no laptop computer to set up or tune - Included full color LED hand-held tuner offers simple setup and easy tuning of basic parameters. Allows users to change some parameters to fine tune base calibrations.
  • Come complete with all hardware to retrofi t EFI on a non-EFI vehicle including fuel pump.
  • Dedicated fuel and oil pressure inputs allows for computer controlled ignition timing if desired
  • System can be upgraded in the future to a Holley "HP EFI System" if desired
  • Small Block Chevy multi port kits come with 36 lb/hr injectors and are designed for up to 500 HP
  • Big Block Chevy multi port kits come with 48 lb/hr injectors and are designed for up to 600 HP
  • Three versions of 4 bbl TBI kits available:
  • 700 CFM with 65 lb/hr injectors - up to 400
  • HP900 CFM with 75 lb/hr injectors - up to 525
  • HP900 CFM with 85 lb/hr injectors - up to 600 HP
i wonder if this set up will work in a crossfire motor
http://www.holley.com/types/Avenger%...%20Systems.asp
4bb:
Old Sep 15, 2010 | 10:46 AM
Ronny's Avatar
Re: High HP TBI
former CF
Old Sep 15, 2010 | 11:15 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: High HP TBI
not trying to be a dick, but read the stickies, they are very helpful, and answer all of the questions you asked, and probably many you haven't asked yet.
Old Sep 16, 2010 | 09:24 AM
InjectorsPlus's Avatar
Former Sponsor
Re: High HP TBI
I am doing some R&D on high flow TBI injectors.
I should know by the end of the week if these work.
If you do build this, I would be more than happy to give you a set to try and let us know.
The 95 lb injectors are the 75 lb simply with higher fuel pressure.
We're looking to go over 100 lbs with 22lbs of fuel pressure.
Old Sep 16, 2010 | 03:02 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: High HP TBI
100lbs at 22 PSI is not bad. The question is how short of pulse duration can this injector provide (1 mSec???)
//RF
Old Sep 16, 2010 | 03:12 PM
Former Sponsor
Re: High HP TBI
I'll let you know when we're done testing. I think I can get more than 100 lbs....
Old Sep 20, 2010 | 09:53 AM
Ronny's Avatar
Re: High HP TBI
I ran 80 lbs injs(GM2560) at 20 lbs. My VAFPR pulls it down to about 2.00 msec or 12 lbs FP at idle. I idle OL at 13.8/1. W/O the VAFPR obviously msec would be much lower. It was B4 I added VAFPR. It did cause idle issues. Other things I did in tune was to lock synch. asynch was cutting off fule. Stabilize idle by locking SA at idle. And moved idle SA higher-lower to find sweet spot. I think I went from 24 SA idle down to 17.
Old Sep 20, 2010 | 10:44 AM
RFmaster's Avatar
Car: 75 Beast
Re: High HP TBI
Hey Ronny
That's what I did on my 383 with 2x 85lb-HR 13301 VFPR. At idle I am pushing 9 to 10 PSI and at WOT VFPR set at 22 PSI. I set flat idle SA at 17 deg. My idle PW is about 1.7mSec close loop (not bad, relatively steady at about 750RPM). The problem is off idle, with no load where MAP = 25-30kPa with engine RPM =900 to 1800 my PW =1.0 to 1.1 which causes RPM surges (FP=9 to 10 PSI!). The darn heads are too efficient and do not require too much fuel (nice problem to have). All of this may become a non issue once I install engine into a car with torque converter providing some load.
//RF
Old Sep 20, 2010 | 10:56 AM
Ronny's Avatar
Re: High HP TBI
off idle = more load lower MAP. So I presume you are rolling along 5-10 mph in 1st gear. I would run lock OL off idle up to 20 mph at 14.0/1 in OL tables and all cells around that rpm and MAP(VAC). May want to flatten surrounding OL cells to same 14.0 and same on flatten surround SA cells.
Old Sep 28, 2010 | 05:28 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: High HP TBI
Those rules don't apply but every engine is sensitive to plenum/runner volume and length.
I'm using #231 TBI injectors @35psi on a 440hp/500ftlb 458, no vr(a)fpr.
Idle is 1.8-2ms.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Stroopwafel
Sep 11, 2015 06:38 AM
92rsvortec350
Sep 10, 2015 10:54 AM
adelane
Sep 9, 2015 08:51 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
