Holley Truck TBI
Old Sep 17, 2010 | 08:15 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Holley Truck TBI
ANyone running the Holley Truck TBI unit???? Or Turbo Citys bored out TBI unit??? Thoughts on these..The Holley is 670 CFM, and the Turbo City is 590 CFM...I think stock is around 530 CFM, or so..Thanks
Old Sep 17, 2010 | 11:17 PM
383TBI's Avatar
Car: 87 Chevy Short Wide
Engine: 383 Vortec TBI
Re: Holley Truck TBI
Im running a Holley tb but with a GM injector pod on top of it.Its the only way to go.From what I heard the Holley injectors suck.
Old Sep 18, 2010 | 12:52 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
thats what they say. thier are a million of threads on these. I have just gotten my hands on one and its not installed yet. so we'll see if thier is some rediculous nightmare with it when I do it.
Old Sep 18, 2010 | 05:58 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Holley 670 has 50mm bores, turbocity's 590 cfm has 46mm bores and is a bored out 43mm TB.
A GM BBC TB has 50mm bores and should be close to the holley 670, can be bored out to 54mm to flow quite a bit over 700cfm, if remember correct.
Intake manifold bores should be = or > then the TB bores.
Here is a pic of turbocity's 46mm TB, works nice, should be good for around 340 fwhp.
https://www.thirdgen.org/forums/atta...e-dsc08258.jpg
Old Sep 18, 2010 | 10:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The new Holley's are fine. They have been using Delphi injectors for some time. These work and can be ID'd by having the connectors come off the injector sideways (parallel to the ground).
The older Holley TBI units used the Chrysler injectors. Which can be ID'd by have a round black plastic cap for a connector. These injectors are worthless.
RBob.
Old Sep 18, 2010 | 10:41 AM
InjectorsPlus's Avatar
Former Sponsor
Holley does not make their own injectors. The only manufacturers for injectors are Bosch, Seimans, Delphi, Denso, SMP (lucas), and something else that is slipping my mind.
I think the holly injectors are BOSCH. They may have switched. The old Accells were made by SMP and they switched to bosch.
As for the Delphi, Mercedes just had a big recall for them.
Just sayin....don't let labels dictate the price you pay or the quality you think y you're getting.
Old Sep 19, 2010 | 02:28 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
RBob.
Yup thats exactly what mine have on them!
F.I. 57 Belair
Aug 23, 2021 01:09 AM
86CamaroDan
Sep 29, 2015 10:08 PM
makaveli09
Sep 15, 2015 10:43 AM
Amillionoh7
Sep 11, 2015 11:36 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
