454 TB adapter plate. (pic heavy)
Old Sep 26, 2010 | 12:09 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
I haven't removed the TB from the adapter yet, but here are several pics of what I think is one of the better adapters available (TBI to Q-jet) the only downside to the adapter, is that it is 1.25 inches thick, and our cars don't have alot of hood clearance. the casting number on the body is 14100837, the spacer is fully heated, but this could easily be stopped by plugging the coolant lines that go to the adapter on the front and back of the body.
the next few pictures show the distribution vanes in the bore of the adapter, I would probably remove all of the top one, and some of the bottom one. I do not know how thick the casting is, and thus how far it could be ported before hitting water, if you bypass the coolant heating feature, it's not as critical (JB weld) if you plan to heat the TB, then you need to be careful.
Old Sep 26, 2010 | 08:01 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 454 TB adapter plate. (pic heavy)
So you are showing this for exactly what reason? For people wanting to put a 454 TB on a 4 bbl intake for a quadrajet? Sorry just not sure what this post is about.
Old Sep 26, 2010 | 08:14 PM
ericjon262's Avatar
it should fit any spread bore manifold, and it's heated, which my understanding is a plus on a tbi motor, esp when some of the best flowing manifolds (IE the edlebrock performer airgap) are not heated it also can be found at junk yards pretty cheap, which is a plus for someone on a budget, also, the adapter itself appears to be very well made, and thought out, not just a piece of plate aluminum with a few holes in it.
Old Sep 27, 2010 | 01:07 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
I thought the goal of any engine was to get the fuel as cool as possible going into the motor? I dunno. A regular adapter looks better than that bulky thing in my opinion.
Old Sep 27, 2010 | 01:10 AM
ericjon262's Avatar
Everything I've heard about TBI motors says they don't like the airgap style intakes, I'm not sure exactly why, but I think it may have something to do with fuel puddling, and atomization issues.
Old Sep 27, 2010 | 09:55 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Eric
I think you have an answer - cold intake manifold walls will cause fuel droplets to fall out from intake mixture and puddle. This is why when using AIR gap intakes a MTS (manifold temperature sensor) is needed to keep mixture under control - especially under acceleration. There are couple of threads dealing with this problem in DIY PROM section.
As for TBI adapter - it is a bit too tall for stock third gen hood line. Pre-heating TBI on top of cold intake intake is just asking for trouble. IMHO, since TBI is a wet flow intake system a fully heated intake works best over wide range of operating conditions. Now - for performance applications that's a different story all together.
//RF
Old Sep 27, 2010 | 03:36 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
If I remember correct, adding a spacer is used to help increase velocity of the incoming air, a bit like the longer TPI runner.
This would happen if the bore has a rather regular in and out diameter.
The one in the pics appers to mainly add plenum volume, wonder if that would give a snappier feeling.
Old Sep 27, 2010 | 08:48 PM
ericjon262's Avatar
what I'm looking at is 2 things, one it allows for a 2 inch bore TB with no modding to the intake at all, two, it's a fairly long smooth transition (if you remove the distribution fins), not just and abrupt sharp edge.
Old Sep 27, 2010 | 09:32 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
but putting it onto a stock tbi manifold is out of the question. so if your doing an tb and intake swap getting a different intake and using this on could be an option. but if you do not have a cowl or hood scoop then it will not clear
Old Sep 27, 2010 | 09:42 PM
ericjon262's Avatar
Definitely out of the question for a stock TBI manifold, it's not the right bolt pattern.
Old Sep 28, 2010 | 04:49 AM
thomas1976's Avatar
Car: 91 Trans am
Apperently not, http://www.castheads.com/faqs_intake_manifold.php
"Radius blended into the bottom" would probably be better then "increasing plenum volume".
Hood clearence aside, it would be interesting to do a comparison test with a performance spacer.
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
buckshot63
Sep 10, 2015 09:15 AM
gt4373
Sep 9, 2015 10:29 AM
