hey guys, have a TBI issue
Old Oct 8, 2010 | 12:49 AM
Bonez92's Avatar
Car: '89 firebird formula
Engine: 305 TBI 5.0
Transmission: T-5 5 speed
Axle/Gears: factory
oh, this is weird, i have an 89 firebird formula 5.0 tbi, my fuel pump is priming and the fuels being pumped all the way to the throttle body but wont spray out of the injectors, i thought that maybe it was an injector problems and went to get new injectors with still wont spray, then i went to the local boneyard (budget wrench and pull) to get a new throttle body setup and still nothing, what could this be guys? any help is much appreciated and thanks in advance
Old Oct 8, 2010 | 02:10 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: hey guys, have a TBI issue
I assume the injector fuse circuit has been checked for power & the fuse is good.
Check for power pulses @ injector connectors, that part of the harness that passes through the TB notch w/rubber grommet is known for failure both open & short.
The next problematic area of wiring is that to the ignition module (in the distributor) as it (the module) serves double duty firing both the ignition and injectors, however the module itself is the usual suspect, given that they seem to die so often some ppl have taken to keeping a spare.
So the module is the most likely failure, I just want you to check the wiring before taking the module out & having it tested.
Old Oct 8, 2010 | 02:27 AM
Bonez92's Avatar
Engine: 305 TBI 5.0
Axle/Gears: factory
where is this injector fuse located? i dont think ive checked that
and if it is the module in the distributor, what do i need to fix it?
BRoss99
Aug 10, 2025 05:08 PM
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
