buzzing noise coming from the tbi
Old Oct 25, 2010 | 08:11 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I have been having idle troubles w/check engine light on, up and down idle, and high idle problems. One of the sensors are probably bad, but I heard a buzzing noise coming from the throddle body when I had the air cleaner lid off. Any help would be appreciated. BTW, I am refering to my 92 RS tbi.
Old Oct 26, 2010 | 05:07 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: buzzing noise coming from the tbi
IAC valve makes that sound wenn adjusting itself.
Could alredy read the error code, check fuel pressure and inspect the IAC valve.
Old Oct 26, 2010 | 07:17 AM
I heard the buzzing sound after I removed the IAC and cleaned it with carb cleaner. I cleaned it, and arount the tb where it screws in. I am still having the idle issues though. up down up down idle, and sometimes it idles five hundred over where it should idle.
Old Oct 27, 2010 | 08:46 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if its still buzzing, the IAC may still be getting stuck. Cleaning may help, but it won't save a worn out or dead unit.
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Sep 17, 2020 08:26 AM
pimp2303
Jul 27, 2017 02:03 PM
xxx3man`
Sep 23, 2015 10:37 PM
