Please help, starting/backfiring problems
Old Nov 10, 2010 | 12:29 PM
Phaite's Avatar
I have an 88 camaro, 5.0/Tbi. It at times has an extrememly hard starting problem and will occasionaly backfire on takeoff and acceleration. I have already replaced the fuel pump, in-line fuel filter, the O2 sensor and changed the timing.
Old Nov 11, 2010 | 07:47 PM
swearingsailor6's Avatar
Re: Please help, starting/backfiring problems
try replacing the coolant temp sensor, could cause those symptoms. Very common problem and very cheap.
Old Nov 11, 2010 | 07:52 PM
Phaite's Avatar
ty, ill pick that part up in the morning and try that and come back with my results.
Old Dec 4, 2010 | 10:57 AM
Phaite's Avatar
I have now replaced the coolant temp sensor and it was still acting up and now i have also replaced the rotor and distributor cap and i am still having the same issues... in fact it will not start right now... it tries you can hear the engine attempt to kick in and it just doesnt get going all the way ... its about 30 degrees out right now if that helps... start better when the engine is warm.
Old Dec 4, 2010 | 10:58 AM
Phaite's Avatar
and i did not have this problem last year... in fact this started happening toward the end of the summer when the car started dieing and i replaced the fuel pump
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
