Idle problem
Idle problem
I have a 90 camaro rs with a 305 fuel injected and it has a throttle body. My problem is it idles high in park and in neutral. i have already changed the IAC valve and the TPS and it has no vacumm leaks any one know what else it could be?
Thanks. Also does anyone know if a steering column from an 89 would work for my 90?
Thanks. Also does anyone know if a steering column from an 89 would work for my 90? Joined: Aug 2009
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Idle problem
Besides putting your thread in the right place, you might want to check this out. And while you're at it read a lot of the stuff in the technical articles section. That's where this is found
https://www.thirdgen.org/tpimod2
