A Pop in the engine
Old Dec 15, 2010 | 10:22 PM
-LateNite89-'s Avatar
A Pop in the engine
Sooooo, while trying to save a few dollars in doing a tune up on the car, I end up screwing up the car. I changed the distributor cap and rotor on the car, (mind you that I followed the the same wire set up on the original distributor cap). Then when I tried to start the car, the engine tried turning over and I hear a loud *POP* sound from the engine.
I had to call the tow truck and get it taken to the closest mechanic shop near my house. So much for trying to save money. Anyways, any thoughts I what I messed up?
Old Dec 16, 2010 | 12:06 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: A Pop in the engine
mixed a wire up and backfired thru the intake.... did it years ago to a 92 v6. blew the oil pan gasket out. good luck
Old Dec 19, 2010 | 09:25 PM
Well, turns out the damage was more severe than I thought. I knew I needed a new starter for a while, just didn't know I was gonna need to replace the entire distributor and starter at the same time. Sucked up a good chunk of change, and it couldnt have happened at a worse time of the year. To my firebird, I love you as much as you're a pain in the *** sometimes.
Steven 86IROC-Z
May 24, 2026 04:52 AM
RazorN8
Jan 7, 2022 11:44 AM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
