What did i break?
Old Jan 8, 2011 | 08:39 AM
transamman83's Avatar
Car: 83 Trans am, and 91 Camaro
Engine: both have a 305.. For now
What did i break?
Hello everyone. I am in the process of putting headers on my 91 rs 305 auto. While taking off the passanger side manifold i broke off a sensor in the head. I cant think what this is. Can anyone tell me what this is? Thank you.
Old Jan 8, 2011 | 09:04 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: What did i break?
between the last two cylinders ? it's the cooling fan switch . good luck .
Old Jan 8, 2011 | 10:12 AM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
91 Rs passenger side in the block would be the knock sensor. Temperature sensor for gauge is in the head on the drivers side between #1 and #3.
Old Jan 8, 2011 | 01:39 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
passenger side head? knock sensor is on the block, so head is the coolant fan switch
Old Jan 8, 2011 | 06:12 PM
UNCLE TOM's Avatar
Jono read a little closer , he said in the head . drivers side , temp.sw. . pass. side , cooling fan sw. . good luck .
Old Jan 11, 2011 | 07:12 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
As mentioned it is the fan switch. You will notice if you start your car cold the fan will automatically come and on not shut off. That is the fail safe mode when the sensor is damaged. It is safe to drive but you want to replace it. 99% of people break this when installing headers.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
