high pressure fuel pump help please
Old Jan 9, 2011 | 05:23 PM
the rookie24's Avatar
Car: 1992 rs stock for now
Transmission: auto
whats up im building a a tpi setup for my 92 rs now i strip a 88 roc and i took the rear end and i want to swap it into my rs now with my tip i need a high pressure fuel pump cause im put bigger injectors and turbo ect... and once i put the rear end in i don't wanna take it back out to put a new fuel pump in right now i have 305 with tbi so can i put the fuel pump in and jus drop it in until my new motors done
Old Jan 9, 2011 | 07:58 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: high pressure fuel pump help please
just put in the high pressure pump for the tpi and use an aftermarket regulator
Old Jan 9, 2011 | 08:21 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Yup basically. Put in a TPI pump and run a different regulator as stated above. especially if you plan future mods.
Old Jan 10, 2011 | 05:33 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Turbo? make sure you get something that's capable of delivering more fuel then a standard TPI fuel pump.
Something like a turbo trans am or s10 typhoon fuel pump, check what the experts in the power adder forum suggest.
Old Jan 10, 2011 | 12:57 PM
Transmission: auto
i dont think you understand im want to put a walbro in tank pump and this weekend im puting a new rear end and i want to know scie the rear end is gunna be out can i put the high pressure pump in now so i dont have do it later when i put the new tpi motor in will the my stock 305 tbi run with high pressure pump
Old Jan 10, 2011 | 01:42 PM
thomas1976's Avatar
Car: 91 Trans am
If it's a walbro 190 then there is no problem, worst scenario you will need a AFPR (adjustable fuel pressure regulator), could modify the stock one
The 255 walbro could be too much for the small return hole of the stock FPR system, In that case an external aftermarked AFPR should do the trick.
Old Jan 11, 2011 | 06:23 PM
Transmission: auto
so what is the worst case if i put in the 255 cause that what i really want because all the mods my tpi is gunna have i jus need the my 305 until i have my new motor done
Old Jan 11, 2011 | 07:05 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The 255 will work fine to put in now. It is not ideal but it will be ok. Many many people have done this, including myself.
Old Jan 12, 2011 | 03:21 PM
Transmission: auto
sweet thanks
92camaroJoe
Jul 29, 2023 07:57 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
