how do i get rid of 110 mph governer
Old Jan 27, 2011 | 09:59 PM
Pitbull91z28's Avatar
Car: 91 Z28 Camaro
Engine: 305 L03 TBI
Transmission: modified 700r4
Axle/Gears: stock
at 110 mph it fells like my fuel is being shut off my motor loses power until i drop below that. i have the LO3 305 TBI, is it in the computer or i read something about its in the distributor? its a little aggravating any ideas?
Old Jan 27, 2011 | 10:34 PM
Stephen's Avatar
Car: 87 GTA
Re: how do i get rid of 110 mph governer
By looking in the Tech. Articles, here on TGO.....
https://www.thirdgen.org/unlimited
Old Jan 27, 2011 | 10:55 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Yup. Basically you can rig a wire up but not recomend for long term driving. Or you can purchase a chip with the governor deleted.
Old Jan 27, 2011 | 11:13 PM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
do the 5 speeds have the governer?
Old Jan 27, 2011 | 11:15 PM
Stephen's Avatar
Car: 87 GTA
[QUOTE=kill4thril;4803756]do the 5 speeds have the governer?[/QUOTE
Yup. Been there, done that.
Old Jan 27, 2011 | 11:38 PM
kill4thril's Avatar
Engine: 355ci
does the ebl flash get rid of it?
Old Jan 27, 2011 | 11:44 PM
Stephen's Avatar
Car: 87 GTA
I don't anything about the EBL system, but it should, I would think it could.
But really.....All it takes is a toggle switch & a little wire, to defeat the Speed Limiter. And splicing the wires in.
Old Jan 27, 2011 | 11:52 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
The ebl flash does get rid of that
Old Jan 28, 2011 | 12:12 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
so how do all of you know theres a gov at 110?
Old Jan 28, 2011 | 01:31 AM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
I don't understand why you want to disable the governer? When i had my 305Tbi 700r4 2:73 gears i was hogging down the road at 110mph and was damn near red lining in 3rd gear.... So wouldn't you blow the engine up if you kill the governer?
Old Jan 28, 2011 | 01:48 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The 110 limit is tire related, it became illegal to let a car go faster then the tires are rated for on it. [people sued] As they often went cheap, 80MPH tires on a car with a 140 speedo.
Old Jan 28, 2011 | 04:30 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
The SPEED LIMITER speed is set in the chip, and needs to be adjusted in the calibration and burned in the chip.
Of cours you can delete the VSS signal to the ECM (like in the tech article), though TCC will be disabled that way and the converter slipping.
If you have EBL flash, you can set the speed limit at around 250mph. Takes 20 seconds to set it up and load the new calibration.
Old Jan 28, 2011 | 04:36 AM
thomas1976's Avatar
Car: 91 Trans am
Originally Posted by 89rs454
305Tbi 700r4 2:73 gears...at 110mph and was damn near red lining in 3rd gear.... So wouldn't you blow the engine up
Will be quite hard to blow up a LO3 @ 4500rpm.
Old Jan 28, 2011 | 07:22 AM
Car: 91 Z28 Camaro
Engine: 305 L03 TBI
Axle/Gears: stock
i had the tanny modified a little and mine does not shift to third until almost 90 with LO3 305 tbi 700r4 2:73 gears
Old Jan 28, 2011 | 08:20 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah it would be hard to blow up. Your trans shifts at 90 but the car still cuts out at 110 there sir...so unless you had it burned from the chip, have ebl flash, or run the wire that cuts off the signal. you cannot go past the 110 in a 305 tbi car
Old Jan 28, 2011 | 09:12 AM
Stephen's Avatar
Car: 87 GTA
I discovered mine in my 1992 305/TBI/T5/3.08 RS at about 2AM against an import. And this was before the Tech Article on TGO even existed.
I discovered the wire mentioned, did it & Brad wrote it up for TGO.
I was winning, until the I hit the Limiter & the engine cut out.
Old Jan 28, 2011 | 03:51 PM
89rs454's Avatar
Car: 1989 SS
True, my shifts were 1st gear-40mph 2nd gear-60mph 3rd gear-110<---way out of powerband from 2nd to 3rd shift, note this was with me shifting myself at 4500rpm. Now i have to ask, how many RPMs can a stock LO3 throw down before it throws a rod? I know my 5.7 can can hit 6k safley, 5500rpms would be my guess for a stock lo3 and thats pushing to it's limit. So pinging 3rd gear at 4500 rpms would leave about 10-15mph gained disabling the governer to reach 5500rpms, so 125mph and that's it. Unless you do the od 4th gear WOT mod which is a complete waste of time for a stock lo3 IMO.
Old Jan 28, 2011 | 05:08 PM
Car: 91 Z28 Camaro
Engine: 305 L03 TBI
Axle/Gears: stock
wish i knew what mine shifted at my tach is broke and always pegged i just watch the speeds it shifts at. thanks for the info!
Old Jan 28, 2011 | 06:30 PM
thomas1976's Avatar
Car: 91 Trans am
I see no difference other then the bore and piston size, they have basically the same block and internals materials.
I remember the stock LO3 configuration, required almost constant WOT to drive @ around 125mph.
With headers, 3" cat, 3" catback with 2x2.5" tips, coustom chip and free flowing air cleaner, it was no big deal to cruise @ around 125mph @ around 3500rpm in 4th. (700r4 + 2.73)
Old Jan 28, 2011 | 09:29 PM
89rs454's Avatar
Car: 1989 SS
I'm sure you can with chips and mods, i would cruise at 60 at 2000rpm in 4th gear so that must be one hell of a chip to make the transmission gearing change from stock.
Old Jan 29, 2011 | 04:19 AM
thomas1976's Avatar
Car: 91 Trans am
You probably did not have the chance to try with a 700r4, 2.73 and facrtory TCC lock-up.
Ed1LE
Sep 30, 2018 09:14 AM
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Zell1luk
Sep 29, 2015 10:36 AM
