Adjusting the Idle
Old Feb 5, 2011 | 05:26 AM
falco0's Avatar
Car: 1990 Camaro RS, 2004 Avalanche Z66
Engine: 3.1
Adjusting the Idle
I have a 1990 Camaro with a 3.1. It idles at around 1800 RPM's. I have to get it smogged and in order to get that done, the car need to idle between 300-1200 RPM's. I changed the TPS already. I see a screw that set's the throttle, but there is a plastic seal on the inside. How do you remove the plastic seal in order to adjust the torx screw?
Old Feb 5, 2011 | 09:16 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Re: Adjusting the Idle
I would look at the idle control motor to make sure nothing is holding it open. Could be built up carbon or a bad motor. And don't mess with the set screw it's preset if you move it it will also move the tps reading. You could also have a vacuum leak causing your high idle.
Old Feb 5, 2011 | 10:00 AM
ex-x-fire's Avatar
The base gaskets for the tbi have been known to go bad, that would be a good place to start so you can really clean up that tbi unit.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
