accelration upgrades for a 305 firebird vin e
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
okay everyone i have a 1992 firebird 305 vin type e and this car is basically my project car and first car i ever had i just recently got a new exhaust sytem for it ( from cat to back) and wondering wat all i can do to get more acceleration
Wat i got in mind:
cam with .447 lift 220 duration hydraulic
headers (either hooker or flowtech) also y pipes
after market air intake manifold
and thinking about a performance chip
like i said first car doing everything myself to learn about engines
so i dont know all terminollogy (and cant spell)
let me kno guys
Wat i got in mind:
let me kno guys
Transmission: 4L80E/4L80E
Re: accelration upgrades for a 305 firebird vin e
Sounds like you're keeping TBI, so I'll move this to the TBI forum.
Car: 1992 Camaro rs
Engine: Lo3
Transmission: T5 swap
Axle/Gears: 4th gen disks 3.23 ratio
Well you will want to make sure you get a roller cam for that motor if its the factory block. I had a problem with my 92 LO3 when i first bought it. Turns out the po had the motor rebuilt with a non-roller cam under roller lifters.
Which isn't good. Do the basics first with a tune up and everything first to get the most out of the base power.
Which isn't good. Do the basics first with a tune up and everything first to get the most out of the base power. Supreme Member
Engine: gone
Transmission: gone
Axle/Gears: gone
Headers and exhaust w/ hi flow catalytic converter will yield best seat of pants gains.
Then address the air cleaner. The stock setup is crappy. So whether you had an open air element. or cold air kit. do it!
After that bump up the timing to around 6*
dont spend any $$$ on a manifold yet
and to really get a lot. change the rear end gears to at least a 3.23. Stock is a 2.76 gear I believe and that is more for highway crusing then performance. The car will feel a ton better with all that!
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Yes,start with the bump in timing to 6* (its free)
Everything that was mentioned by UnderCover89TBI.
Those are the basics
Engine: gone
Transmission: gone
Axle/Gears: gone
I guess a cam couldnt hurt either. But it really depends on what you wanna do. Itd be nice to do a head swap, cam swap, new timing chain etc at the same time....
Car: 92 firebird
my uncle selling me this cam with a double timmin belt and cover (plus feul pump) for 200
and for the heads wat do u believe would be the best?
and cheapest
also wat do u believ would be the best headers for it? hookers or flowtechS?
thank yall alot not going to lie still learning as i go
Thanks for the help!!
and cheapest
Engine: gone
Transmission: gone
Axle/Gears: gone
hookers.
Heads it depends. thier are multiple purposes for different heads. I dont know where you are located, the most cost efficient is a set of vortec heads but they require an external egr if you have smog etc.
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Hooker 2055's work great. Open element air cleaner. Look for a used roller cam. 220@50 is a lot of duration. May be a pain to tune especially if lsa is < 112.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Removing the smog pump will clean up the engine bay but won't add any power. Vortec heads are a decent option but need a lot of supporting mods to utilize them correctly. If your car is stock you should start elimination air flow bottle-necks in order of importance.
Exhaust (headers to tialpipe
Air Intake
Chip Tuning
Cam
Chip Tuning
Intake manifold
Heads
More Chip Tuning
Air Intake
Chip Tuning
Cam
Chip Tuning
Intake manifold
Heads
More Chip Tuning
Car: 92 firebird
so more duration is bad and less is good??
Car: 92 firebird
okay cold air or open air wich brings more?? and also i found this cold air intake on ebay for forty bucks but all the pics show it hooked up to a supercharger i think here the link
http://cgi.ebay.com/ebaymotors/PONTI...item56406c7f5d
will it fit my stock aircleaner???
also if i rebuilt my heads will that be cheaper than buying new ones???
Car: '90 RS
Engine: 377 LSX
Car: 92 firebird
It depends on what your goals are. If you want to run the stock cam, than your stock heads are fine. If you want to run a cam that makes power in the lower RPM region, than the stock heads are fine. If you want to run a cam with higher than .480" lift, then you should look into some machine work to cut the guides and replace the pressued in rocker studs for screw in units. It would be better if you could explain your goals first. We can then guide you on the right path from there
lolok i want more torque and hp for acceleration rpms wat would u advise?? idk that much for rpms (learning as i go)
cam with 447 lift
Car: '90 RS
Engine: 377 LSX
Well....Bolt ons will go a long way for your combo. Also, a small cam swap (LT1) with tuning will give you great off idle power. This all depends on your ability to tune your chip (DIY and not mail order). Cam lift is not what you want to look at when choosing a new bump stick. LSA, overlap, and duration have 99% more impact on your power band than cam lift. I would recomend taking some time to search this board and read, read, read. The more you learn the less money you will spend and the faster your car will be.
Car: 92 firebird
main reasons im getting this cam is for every thing that is included
cam duration 220
lifters (hydraullic) .447
double timing belt
cover for belt
and feul pump
all for 200
i believe is good buy opinions??
and thanks for the help and trust me for thhe past weeks all i have been doing is reading!!!
cam duration 220
double timing belt
cover for belt
and feul pump
all for 200
